New 370D owner
/ New 370D owner #41
Did you say work bench? Lmao
Kinda hard to use the vise though...
/ New 370D owner
I got to try out the snowplow blade I cobbled together, It works perfect. It think the blade came off an older Lawn tractor it's very heavily built. I can't believe how easily this tractor pushes large amounts of snow. I will definitely do a couple of modifications in the Spring. Hydraulic angle for the blade and widen the blade. I have a question about the differential lock by the foot board of the tractor. I was just reading the owners manual and it says that it is on a spring and you can lock and unlock the diff. The one on my tractor is laying right on the floorboard and I have tried to lift it up out of curiosity before and it wouldn't budge (I had no idea what it was for until a few minutes ago). If the diff is locked all the time is this a problem? I have never noticed any problems with the operation of the tractor.
/ New 370D owner #43
You probably ought to get some PB Blaster or other good penetrating oil and get that loosened up. I would think it would be hard on the differential to be locked all the time. I've heard of this with others too. My Mitsubishi 1450 is similar to the 373 and the 470 as well except for the 470 having a larger engine. When I got the 1450, it was froze up the same way. I think I was able to take a hammer and gently tap on the back side of that little pedal to make it pivot back up. I used some PB.
/ New 370D owner #44
Chances are your differential is not in the locked position. If it was it would be very noticable going around corners to the point that you'll skid one of the rear tires and it will be very difficult to steer especially on concrete or pavement. I had the same problem with mine and once I freed it up where it goes into the transmission case all was well.
/ New 370D owner #45
Diff lock foot pedal is a little deceptive.
Make a turn, if the inner wheel is skidding/pushing, the diff lock is stuck on.
If its not, stop, press down on the foot pedal, and repeat. May stay locked in even if you let off the pedal till you stop moving or change directions as it will tend to stay engaged when your putting power though the rear wheels.
/ New 370D owner #46
Demigod, mine is the exact same way. I pay it no attention.
I use my right/left brakes all the time when I'm shredding. I figure it wouldn't turn right if it were locked into position.
/ New 370D owner #47
Just got a 370d myself, mine was stuck engauged also. I sprayed the pedal and lever with PB, took the pedal off. and used a hamer and pry bar to move back and forth till it loosened up. Well worth the 15 min to fix. Its alot easier to turn in and out of tight places now.
/ New 370D owner
Thanks for all the info. It must not be engaged then. I will see about freeing it up and making it functional cuz' I had to tow my snowmobile up from the backyard through some deep snow and I had to keep pulling myself forward with the plow blade. If I had diff lock I don't think I would have been getting stuck. Thanks again.
/ New 370D owner #49
Yes, you'll want a functional differential lock. I wish these tractors came with front differntial lock sometimes. Occasionally you'll wind up with the tractor "teetering" on the ground where one tire on the front and rear are basically in the air. Differential lock is a life-saver then as well as in other circumstances.
/ New 370D owner
Well, I've sold my Beaver with all of the attachments except the pallet forks. I found a good deal on a 2004 3 cylinder diesel cub cadet 7264 with FEL and front mounted snowblower. I wanted to mention before I left this forum that I found what I think is a pretty nice and very lightweight quick attack from these folks Skid Steer Mini Universal Adapter
It's what I'm going to weld or bolt to my cub and is what I had on my Beaver. The plates to go to your attachments can be found on Ebay pre made usually under Dingo or Vermeer attachments, but they are very easy to make from plate and flatstock if you have a welder.
/ New 370D owner #51
That adds a lot of weight to the front of a little tractor. I did the john deere type quick attach to mine. quick to make, cheap, and light.
/ New 370D owner #52
My names mike i just bought a mt372 and want to build a complete loader for it wat would u do diff on it to improve it. and where did u run the hyd on the tractor did u use a pto pump or T off the pump it self off the engine cause all i got is a 3 point and i know where the pump is but theres no remotes in the back. if u would let me know.
/ New 370D owner
Hello Mike, I didn't build my loader for the tractor I had. But if you look up above your question there is a gentleman whos member name is Freakingstang. Click on his name and he has a thread with a loader build he did from scratch. I would read through that first.
Unverferth 632 (A64119)
Unverferth 632...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
KUBOTA BT1973 - 17 1/2" EXCAVATOR BUCKET (A64280)
KUBOTA BT1973 - 17...
80003CFL (A61568)
80003CFL (A61568)
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
