New 3320 pics
/ New 3320 pics #21
Thanks for the info, Rob. I was not aware that you could change which direction it vents. Before ordering mine, I saw some threads on here that mentioned the exhausts effects on your crops, but I figured it had to be better for the operator too! I only have 30 hours on mine, but the soot is beginning to appear on the loader. Hopefully I will have mine installed before the end of the week.
/ New 3320 pics
Yep, I was out today for about 5 hours and the fumes were so low I didn't notice them. In fact I didn't think about the lack of order until I was off the tractor for the day.
Rob
/ New 3320 pics #23
Great looking rig Rob , What dealer did you get it from?
/ New 3320 pics #24
:thumbsup::thumbsup: two thumbs up for sure ... I'd kill to have that BH ! :licking:
/ New 3320 pics
Hi Kevin,
Thanks, I've been buying from this dealer awhile, they're very good to me:
Delaware Sports Center, Walton, NY.
Jon Armstrong
There's a big dealer in Oneonta and Syracuse with three or four other locations but I like the small guy. When I had a problem his mechanic, Dale, was at my door that afternoon. When I blew a drive shaft he called me the next day to tell me the parts were in.
Rob
/ New 3320 pics #26
Stout looking machine Rob, started thinking of all the work I could get done with that hoe. Looking forward to some before and after photos once you convert to the wide stance.
Enjoy!
/ New 3320 pics #27
I ordered the vertical exhaust because I liked how it looked. The tractor was delivered without it because the kit was backordered so I have been using it for a few weeks without it. I have noticed the fumes more than I thought I would.
My vertical exhaust just came in and the dealer will pick up my tractor to install it later this week. I am looking forward to smelling the fresh air.
My previous tractors (Deere 670 and 790...virtually the same machine except for the engine and tire sizes) both had the vertical exhaust. My current tractor, a Deere 4400, has the low mounted horizontal exhaust.
I doubt I change over, but I definitely prefer the vertical exhaust with one caveat: When that vertical pipe hits a low hanging branch, that branch can really snap back as the tractor passes by. Just something to be aware of...
/ New 3320 pics #28
Hi Kevin,
Jon Armstrong
Rob
I've been looking for a tractor in that size with a loader and backhoe just like you got. I must not be too far from you as I am between Delhi and Stamford. I really like the MF's at Eklunds but come from a Deere familly. We have always had good service at Del Sports. Do you mind telling me what that setup cost? A pm is fine.
/ New 3320 pics
Sure I'll PM you and maybe you can drop by and check out my 3320 too.
Rob
/ New 3320 pics #30
I got my tractor back today with the vertical exhaust installed. I took it for a quick spin through the woods to try it out and I never smelled any fumes! I did pay attention to branches, but we have cut most of the low hanging ones. None the less, that is good advice.
Another advantage I hadn't thought of is that the exhaust stack clears out the spider webs before I get a face full of web. We have some Texas-sized spiders that build Texas-sized webs between the trees here.
/ New 3320 pics #31
Awesome pics and a fine choice of machines I might add. :D Sure wish I had the BH, just couldn't justify the price for how often I would use it.
/ New 3320 pics #32
Looks like a great set up! Nice pics. Enjoy!
/ New 3320 pics #33
Good looking unit, congrats to you.
/ New 3320 pics
Thanks gang!
By the way I just reversed my back tires. (fronts don't do much as the front axle floats) Wasn't bad, I lifted it by the BH stabilizer arms and just touched them up or down until I could get the tires on the axle landing. My tires aren't loaded though. Took me about 45 minutes for the whole job. Looks like I gained about an inch or so overall.
I used a 3/4 bar, 7/8 socket and one of those 4 way tire irons.
My new distance from middle of tire to middle of tire is 44" almost exactly. If you have new wheels there's a rubber line so it's easy to find the tire center.
If someone has their wheels in the narrow position you can measure them and figure exactly how much you'll gain by doing the change.
Rob
/ New 3320 pics #35
Thanks gang!
Rob
My R4's are loaded and they are very tough to move. Even my Turf Specials require a bit of strength to more even though they are not loaded.
/ New 3320 pics
Yes, Loaded tires are a bit to move around. I think you should have at least two people to move them.
Rob
/ New 3320 pics #37
Rob
Oh no way with my ego, I can move them all, just very slowly:laughing:
/ New 3320 pics #38
Yeah, you can tell us about that ego when you're flat on your back with a herniated disk or two...
/ New 3320 pics #39
Rob, congratulations on the new tractor. Like I always say, work will seem more like play but you already know that. Have you had a chance to give the 485 BH a good workout yet , and if so, what are your thoughts?
/ New 3320 pics
Thanks Sunnyside,
The BH should get a work out this week, I had to take it off to bush hog my fields. I'll give a full report on the hoe and the thumb as soon as I work it a few hours.
Rob
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
UNUSED AGT- YC-26G SAWMILL (A64281)
UNUSED AGT- YC-26G...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2026 Kearney 7'x20' Trailer (A64119)
2026 Kearney...
