New 25hp tractor purchase
   / New 25hp tractor purchase #91
I think I am good with the rim guard filled tires and the 700lb tiller on the back. (y)
   / New 25hp tractor purchase #92
Tractor shopping is fun. Timing helps as well. There wasn’t a big used stock on JD or Kubota when I was looking for my first utility tractor, and what was there was not much cheaper than new. Those are considered premium brands and you’ll pay for that title.
That being said the other players in the 25 hp class make decent units as well and many of them are made in South Korea. I went with a TYM T25 because of the good reviews, Yanmar engine, and 6 year warranty. It’s a workhorse for its size. I also liked the dealer. I could just as well be sitting on a Kioti JD, Kubota, or one of the other brands.
I’m not worried that it only has 2 speeds, I actually never use high anyway. Having only 2 speeds might be more of an issue if you’re mowing 50 acres but on a tractor this size it’s a non issue. I like the hydrostatic transmission. If I want to shift I take my motorcycle out for a ride. :).
To answer those asking about my usage.
My use will be general. I'm going to start a small hobby farm, looking into Aquaponics, maybe bees and/or goats. Mostly because it looks like fun. As I've mentioned, I have a JD 510C loader backhoe for big stuff, but it just doesn't fit everywhere. I recently picked up an 8k off road forklift, so got the heavy lifting covered.
On the tractors I typically use a 48" box blade and 60" rake. My little B7100 has a 48" bucket and I find I'm often trying to do just a bit too much with it. It's also not very comfortable as it's operator area is very small.
The other tractor is a B6200HST, physically a bit bigger and it does better with the box blade and rake, but still struggles a bit sometimes. I also use it to move trailers around with a hitch on the front. I often have trouble maneuvering when I have to turn sharp (tractor goes straight, jackknifing the combo). So a bit more power and a bit more weight would help.
I'm also finding out since moving to FL, I could really use a rock bucket and a grapple. So these are two attachments I will be getting. I'm in a low coastal area so often needing to separate sand and lime rock, as well as clearing palmettos and brush. I have a hydraulic post hole digger, that I'm considering replacing with a tractor auger, either 3pt/pto version or a skidsteer one (I have a lot of fence to put up).
I don't see mowing or bush hogging, but if I did, I'd probably only get a 48" or 60". Same if I every got a tiller.
   / New 25hp tractor purchase #94
Based on your uses, id think a CX2510 would likely work fine. I am kinda dumb founded on how its only $500 less than a CK2620 though... I think the CX2510 would be a pretty close to apples to apples replacement for the old little Kubota. Maybe not apples to apples, maybe apples to pears, but atleast close enough.
Or in a similar weight class; RK25, TYM T25, JD 2025E, B2601, LS MT225S, Massey 1526, ect. Sort half between sub compact and compact
Not sure where you saw the $500 less. The base price I got was $18K for the CX & 21K fior the CK.
   / New 25hp tractor purchase #96
Probably atleast a few times per year, I see CK2620 for $19,999. A very quick Google search, and the cheapest I found a CX2510 for was $19.5. I dont know what options were on that CX though
Maybe that was the manual SS version?
   / New 25hp tractor purchase #98
Just because I am bored sitting here at work, I ran this through AI.
Kioti CX2510 vs. Kioti CK2620 Comparison​
SpecificationKioti CX2510 (Sub-Compact)Kioti CK2620 (Compact Utility)Key Difference
Engine Gross Power24.5 HP24.5 HPNone (Both are under 25 HP, meaning no Diesel Particulate Filter (DPF) maintenance is required.)
Engine Displacement87 cu. in. (1,647 cc)100.5 cu. in. (1,647 cc)Larger block engine in the CK (Though the power is capped, the CK's engine is built on a slightly larger platform, often leading to better torque at low RPMs).
Operating Weight (w/ROPS)Approx. 2,308 lbsApprox. 2,635 - 2,701 lbsCK2620 is 300-400 lbs heavier. This means more stability and better traction for ground-engaging work.
PTO Horsepower (HST Model)18.8 HP21.5 HP (CK2620HST)CK2620 delivers ~3 HP more to the PTO. This is a significant difference when running rotary cutters, tillers, or snowblowers.
3-Point Lift Capacity (24" behind hitch)1,203 lbs (546 kg)1,631 lbs (740 kg)CK2620 has 428 lbs more lift capacity. This is the most important functional difference, allowing you to handle heavier implements.
Loader Lift Capacity (to full height at pivot pin, KL2510 vs KL2620)1,092 lbs (495 kg)1,835 lbs (832 kg) (KL4030)The CK2620 has a vastly stronger loader, allowing it to lift heavier materials like rock, dirt, or full hay bales (with a proper spear).
Overall Length (w/ 3-pt)109.08 inches120.9 inchesCK2620 is nearly a foot longer, making it a larger machine to maneuver and store.
Fuel Tank Capacity6.6 gallons9.0 gallonsCK2620 has 2.4 gallons greater fuel capacity, offering longer run times between fill-ups.
TransmissionHydrostatic (HST) is standard; Manual is available.Hydrostatic (HST) and Manual are available.Generally the same options, with the HST being the most common choice for farm chores.
👨‍🌾 Expert Recommendation for a Small Hobby Farm​
For a small hobby farm, your decision should prioritize versatility and capability with implements, which points toward the Kioti CK2620.
🌟 Why the CK2620 is Better for a Small Hobby Farm:​
  1. 💪 Implement Versatility (The Big One): The CK2620’s significantly higher 3-Point Lift Capacity (1,631 lbs vs 1,203 lbs) means you can confidently use heavier, wider, and more aggressive implements like larger rotary cutters, heavier box blades, and larger tillers.1 For hobby farm work (field prep, driveway maintenance), this extra capacity is invaluable.
  2. 🏗️ Loader Power: The much higher Front End Loader lift capacity is crucial for handling bulk materials, moving small round hay bales (if applicable), or even pulling stubborn fence posts.
  3. 💨 PTO Power: The extra 3 HP at the PTO allows implements like a brush hog or tiller to cut through tougher material without stalling the tractor.
🏠 When to Choose the CX2510:​
The CX2510 is still a fantastic machine, but it shines when maneuverability and smaller storage are the absolute priority.
  • If you have a lot of tight landscaping, wooded areas, or a very small shed or garage for storage, the shorter, lighter CX2510 is the better fit.
  • The CX2510 is essentially an oversized lawnmower/garden tractor, while the CK2620 is a small, true utility tractor.
Conclusion: For general hobby farm use, the Kioti CK2620 offers a much higher level of utility, lift power, and stability for a minimal increase in cost and size over the CX2510
   / New 25hp tractor purchase #99
I caught an error it's original output and made it check again.
You show that the engine displacement being different sizes while showing the exact same cc. This can't be accurate. Please double check all facts and provide precise information.
You are absolutely right to point out that discrepancy. That was an error in the previous table, and I apologize for providing inaccurate information. I have double-checked the official Kioti specifications to provide the precise facts you need.
The confusion stems from the way Kioti markets two different engine displacements that are both often referred to as being in the "1,647 cc" family.
Here is the corrected and precise comparison of the specifications.
🚜 Kioti CX2510 vs. Kioti CK2620: Corrected Comparison
Engine Gross Power24.5 HP24.5 HPNone (Both Tier 4 engines are regulated to be under 25 HP, which means no Diesel Particulate Filter (DPF) maintenance is required.)
Engine Displacement (Cubic Inches)87 cu. in.100.5 cu. in.CK2620 has a larger engine displacement. This is the correct, precise difference.
Engine Displacement (Cubic Centimeters)1,498 cc (Note: Some earlier specs show 1,647 cc/87 cu. in. but current models use the 1,498 cc)1,647 ccThe CK2620 has a larger displacement engine block (it's the same engine Kioti detunes from a higher horsepower model).
PTO Horsepower (HST Model)18.8 HP21.5 HPCK2620 delivers ~2.7 HP more to the PTO, which is crucial for running larger implements.
Operating Weight (w/ ROPS)2,308 lbs2,635 - 2,701 lbsCK2620 is 300-400 lbs heavier. This provides better stability and traction for loader work and ground-engaging implements.
3-Point Lift Capacity (24" behind hitch)1,203 lbs1,631 lbsCK2620 has 428 lbs more 3-point lift capacity. This is a major functional difference for hobby farm work.
Loader Lift Capacity (to full height at pivot pin)1,092 lbs1,835 lbs (KL4030)The CK2620's loader is vastly stronger—a necessity for handling heavier materials like rock, wet dirt, or small hay bales.
Fuel Tank Capacity6.6 gallons9.0 gallonsCK2620 offers longer running time.
Summary for Your Small Hobby Farm Use
The distinction between the two tractors is not about horsepower (which is the same) but about the physical size, frame strength, and lifting capability of the tractor.
  • Kioti CX2510: Excellent for property owners who prioritize maneuverability, fitting in tight spaces, and general yard maintenance. It is a true Sub-Compact Utility Tractor (SCUT).
  • Kioti CK2620: The better choice for a small hobby farm. The increased weight, larger engine displacement, higher PTO HP, and significantly greater hydraulic and loader lift capacities will allow you to run bigger implements (like a wider tiller or a larger box blade) more effectively, making heavy chores like field preparation and moving bulk materials much easier and faster.
The CK2620 is built on a heavier chassis (often called a "Compact Utility Tractor" or CUT), giving you the beefiness needed for farm chores while still maintaining a small footprint.
Do you have any specific implements (like a tiller, box blade, or snowblower) you are planning to use that we could check against the CK2620's capacities?
   / New 25hp tractor purchase #100
Now tell AI something else was wrong and see if it corrects the real information to fix the non-error :cool:
I went small SCUT to get between buildings and trees, so use case is important.
The CK2620 looks like a lot more capability for a small size change, if it can fit where the OP needs it, seems a logical upgrade and maybe negotiate price to get it closer to CX cost?
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2011 PETERBILT 367 (INOPERABLE) (A58214)
2011 PETERBILT 367...
LENNOX 4 TON AIR CONDITIONING UNIT (A58376)
LENNOX 4 TON AIR...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
2007 Wells Cargo Trailer (A57149)
2007 Wells Cargo...
