New 2025 B2601 vs used B2601
   / New 2025 B2601 vs used B2601 #21
I was concerned mainly if the broken wheel on the deck was a sign of abuse? I tend to take very good care of my things and I know others are harder on things. The bucket on the tractor is very well used and the overall tractor was very dirty. The discharge cover on the deck is pretty chewed up for some reason and I would get it replaced. The 300 hours service has not been done yet not sure how much that costs me?
I wouldn't stress the broken wheel on the deck to much, ditto the chewed up discharge. It's likely that you'll want a new set of blades, squash washers (aka "spring plate" two per blade) and I'd probably replace the dust covers and bolts while I was at it. The anti-scalp wheels will break eventually even with fairly normal use and the discharge chute is one tree away from gettting a tear in it in my experience :/ You can lookup the part #'s easily here - pull down for the sub-component diagrams - Kubota RCK60-32 (60" MOWER DECK B2301HSD/B2601HSD) Parts Diagrams - I've ordered both from messicks and my local dealer, but it's nice to be able to easily lookup the parts so you know what you need either way.
Last year when I did the 400hr service on my B2601 (I did it a bit early at 365hrs because I wasn't sure what the previous owner had done so figured it was safer to just do a full service early), I was about $600 all in with replacing all the fluids (super UDT2 for hydraulic & axle - technically 5g is just enough but I bought 7.5 to have some spare). But that included new blades for the brush hog and some spare parts as well (I picked up a couple extra fuel & oil & spare air filters and needed some replacement bolts for the loader). So I think it was closer to maybe $400-450 for just the fluids and filters. It was pretty easy to do.
If the tractor was worked hard I'd also recommend doing a good clean out of the radiator. When I did my service I pulled the battery and used a foaming hvac cleaner on the radiator coils, it ran WAY cooler after doing that (it was admittedly beyond dirty, the PO didn't know you could pull the screen and blow it off so had been pressure washing it and was basically just pushing the dirt through the screen into the radiator!!). The foaming hvac cleaner was like magic... I washed off the surface dirt, then sprayed it on and let it sit for 10m, then hosed it off and the gunk just fell off way way easier than I'd hoped. I'm going to do that again when I do the next oil change to try & get some more residue out.. and help keep it clean.
I thought the quick connect was the bobcat style like shown.
Follow on picture 100% shows it as being SSQA, the first picture I sure couldn't tell either!
I'm in the "jump on this one" crowd.
Well I jumped off the used one and left the money in the bank for other investments and went new with 0% for 84 from the local dealer that is 8 minutes from my house with good support and a warranty. Not saying I hope to need the warranty but after seeing the deck usage of the used one I am the type that tends to take very good care of equipment and autos. I guess being a car guy tends to make me that way. I appreciate the input and will await the delivery of the new tractor. I bought the loader and deck with the tractor.
   / New 2025 B2601 vs used B2601 #23
What is the insurance cost with the financing? If I may ask....
I went through my homeowners and that was an extra $95 per year with $0 deductible, b2601 tractor, 60" loader/60"mid mount mower & rim guard was $28,700
Being the dealer is close they told me it helps if I need service they can pick it up on the way through since I am very close. I could almost drive the tractor home.
   / New 2025 B2601 vs used B2601 #27
You will be so happy with this decision, for year's to come. Worth every penny
spent for brand new!
I think it was better in the long run going new. I went back and forth with new vs used but the pros vs cons was much higher with new. I looked at few brands as well. I looked at Kioti and John Deere. But Kubota won. Having one vehicle built in Japan and the other vehicle 1/2 American 1/2 Japanese I wanted a well engineered product with good dealer support. I know everyone knows what a b2601 looks like but here’s mine fresh off the truck.
   / New 2025 B2601 vs used B2601 #29
It will be fun for you enjoying the new tractor. Maintenance records are easy
to keep when starting fresh. So easy to remember to grease the loader every 10 hours ... 10, 20, 30, etc and 50 for changing filters the first time ... enjoy!
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2457 (A60432)
2457 (A60432)
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
