New 2011 Cub Cadet Garden Tractor!!
   / New 2011 Cub Cadet Garden Tractor!!
As far as I know it will be Dealers Only! HomeDepot and Lowes Never carry the higher Quality Units! Their type customer is normally in the Lower end product. Home Depot and Lowes like the Higher HP and Larger Mower decks But Low end , Lower Quailty Units for Price Points.
   / New 2011 Cub Cadet Garden Tractor!! #43
I think the 2011 Cub looks nearly identical to the current 2500 series lineup. Other than the colors and the deck. I cant really see that much of a difference. I wonder if the brush guard on the front will be an option.
Michael
   / New 2011 Cub Cadet Garden Tractor!! #44
Have these machines hit the dealers floors yet??
No, I would guess they should be available in Early Spring??
   / New 2011 Cub Cadet Garden Tractor!! #47
It's good to see that they addressed the steering and possibly the deck. Those are the only real faults with my 2544. I've already broke the steering once and it's getting sloppy again. The cut with the 44 is pretty bad as well. Other than that it's a work horse and I much prefer the older metal style hood over the newer models.
   / New 2011 Cub Cadet Garden Tractor!! #48
..The cut with the 44 is pretty bad as well.
No kiddin'?? My 2544 left a beautiful cut for me. In fact, it seemed to look better than the cut from the fabricated 44" on my Z-Force.
   / New 2011 Cub Cadet Garden Tractor!! #49
I've gotta side with Morkai. I've never been impressed with the cut of my 2544. It's not BAD, but it's not great, either. My neighbor's Ferris 1500Z cuts far better and at twice the speed. I mowed with it over the summer while they were on vacation and went through grass 7 to 8 inches high at least taking it down to maybe 4" and the speed at which the deck could process that much very thick, very green grass was amazing.
On the contrary, my 2544 would have went through it OK, but left a lot more clumping and left a lot of it uncut and merely bent over. I do think the Ferris has even higher tip speed than the 2544, though. Between the Kawi engine wound up and the deck, you start to look for where the B-29 is...:D
My theory (after pulling the Ferris apart to sharpen his blades) is the 2544 deck has the blades mounted up too high inside the deck. If the grass is tall, it is still bent over by the front of the deck by the time the blade gets to it. The Ferris has the blade even with the bottom of the front lip and there are actually adjustable baffles at the front of the deck to control the grass intake.
I would bet that spacing the 2544 blades down 1/4" or so would make a big difference in cut quality. Otherwise, I see no reason it can't cut well - it's a deep, well baffled deck.
New 2011
   / New 2011 Cub Cadet Garden Tractor!! #52
<snip>
Yeah, if you have a nicely manicured lawn that you never let get very high, I'm sure it'll cut fine. However, if you have weeds and Bahia grass and some thick stuff to deal with it's not all nice and neat. ESP the Bahia, it loves to leave some standing.
I have actually been thinking of getting a 50" deck and replacing my 44 with it. The only real difference in the 2544 and 2550 is 1hp. I checked with the dealer most of the parts (like spindles) are the same between the two. I think the tension mechanism is different. The deck pulleys were the same part# as well I think. That should work out to a marginally higher blade tip speed with the same pulley ratio I would think.
   / New 2011 Cub Cadet Garden Tractor!! #53
If your replacing the deck just go all out and get the 54" cut. It's a very well made deck and cuts very well
   / New 2011 Cub Cadet Garden Tractor!! #54
I don't think you'd even notice the 1hp. I've never been able to bog my engine with the 44" deck no matter how tall the grass (and my grass is THICK). It would pull 50" no problem.
I don't think it's as much a blade speed issue on the 44" as much as it's the blade to deck relationship. That center blade sits up high in the deck behind the front roller and a pretty wide, flat "lip" that is lower and parallel to the blade (roller/deck front edge/lip/blade-> O|___----- <- grass never has a chance to spring back up).
I'm going to try adding some 1/8" thick spacers under the blades this spring if there's enough thread on the spindles. Even 1/16" would help. I'll also look at modifying the front edge of the deck area so it doesn't push over the grass as much. I'll use my neighbor's Ferris ZTR deck as a reference since it doesn't leave a single blade uncut no matter how fast or how high the grass is. Wonder if he'd notice a yellow deck under his mower????? :D
   / New 2011 Cub Cadet Garden Tractor!! #55
EuropaChris, you might be right. It does seem as most of the issues are near the center. I went to the high lift blades and they cut better as they help pull the grass back up into the deck. I might try the spacer idea, I believe there is plenty of thread.
I've only bogged my 44 down once when I ran over a large ant bed, but it didn't stop the engine, just smoked the belt. :laughing:
cubmaster, I guess either would work. The 54's were only 2hp difference. I just thought the 54 might be too much. I only checked on the 50 at the dealer for part compatibility, but I imagine they're all about the same on most parts.
   / New 2011 Cub Cadet Garden Tractor!! #56
Personally I'd opt for the 54" my dad has the 50" on his and if there is anything he doesn't like it's the deck. It is a lighter weight deck and has limited adjustabilty compared to the 54, Plus the 54 is made to ride the ground which give a good even cut. The 2544 tractor should have no trouble turning the 54... anyone else care to give an opinion ? :)
   / New 2011 Cub Cadet Garden Tractor!! #57
I think I'd want the 54" deck over the 50" too. As for HP, I think you'll be fine pulling the 54" with what you have. Dad's JD 345 pulls a 54" deck just fine, even in tall, thick, wet grass with a 20 hp Kawi.
   / New 2011 Cub Cadet Garden Tractor!! #58
When I bought my 2518, I had the choice of 44 or 48 inch deck size. The tractors were the same. I have the 44 because that is what the dealer had in stock.
I have noticed with my 44 inch deck. When the grass is too long it will not cut as well in the center. If that happens I raise the deck up a notch and that seems to help.
The grass also builds up in the center which probably affects the airflow and doesn't lift the grass. This is usually worst in the spring when grass grows like mad. I try to clean it every week during this time.
My beef with the 44 inch deck is the discharge opening. I think it's too small. The grass tends to clump at the opening. The Craftsman i had before had the same problem. The 42 inch deck had a small opening and needed cleaned all the time.
   / New 2011 Cub Cadet Garden Tractor!! #59
yeah it's a shame the 48 was discontinued , it was built alot like the 54" they both ( the 48-54) have very large side discharge chutes I can honestly say I have never clogged it up and it actually stays fairly clean under there as a result of the large opening. the current 50 has a large opening too but it's just a lighter deck.
   / New 2011 Cub Cadet Garden Tractor!! #60
My 2010 fab'd 44" deck has a small discharge opening. I'd bet the new 2011 fab'd are the same. This deck has unbelievable suction and discharge force, but I'm not sure I like the cut quality yet. With the rear striper roller system it's designed to cut lower, but if I have mine set low so the stiper works, the deck gets bounced, jostled and banged around so badly, it locks itself back into the upright travel position. Very frustrating :( It's a nicely designed machine for the money, it just needs a few inches more of clearance between deck and machine. Here's mine just before I blew it off and put it away for the season. It's got about 30hrs on it. I took the massive plastic discharge chute cover off.
Joel
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
