Comparison New 1023E vs 1025R decision
   / New 1023E vs 1025R decision #31
Thanks. I'll be rechecking level by the book. I've raised the lift links as it came from dealer because of cutting too low. I may need to adjust back down so gauge wheels come in contact quicker with the ground.
The gauge wheels are all the way down, but higher off the ground than the recommended 1/4"
You can remove those pins with the wire clips on top of the gauge wheel shafts and go down 2 additional holes.
It took me a whole year to figure that one out:eek:
I had forgotten that when I stuck the ROPS in garage opening and had let air out of rear tires to get out. They had about 10# air. I put 22 # in and it mows Much much better. I also adjusted the angle track going up the hill in front. Looks pretty good , but the deck is higher in front than back. I'll be adjusting front to be 1/4" lower than rear per manual. This should make it even better. I also have the deck level gauge to get the side to side perfect. Can hardly wait to mow again!?
Already have set of chains ordered hoping for snow... Crazy!
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
CATERPILLAR CS54B...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
