Netscape/Firefox tweak
/ Netscape/Firefox tweak #21
Seems to be working better.
I do have a questions.
<ul type="square"> [*]Spell Check does not seem to have a very good dictionary. Is there a better one? [*]When trying to make changes to a reply. The only way I can make changes in middle of replies is to add at end of reply. Then cut and paste it to the location in the reply that I want. Is this the way its supposed to be done? [/list]
/ Netscape/Firefox tweak #22
I think you are talking about site specific features Ron. If you are talking about useability for TBN with Mozilla. Spellcheck is handled by Spellcheck.net and is fed the data from the input box on this site. This is not controllable by Firefox or any web browser for that matter.
I don't have the problem you are talking about in edit mode for TBN messages with Firefox or IE either one. Can you elaborate on what you are seeing?
If I post my message and then go back and hit edit, I am presented with a "Post" input box with my old message already in it. I simply use the mouse, click in the text in the place I want to start typing and do it. Is this not what you are seeing?
/ Netscape/Firefox tweak #23
I'm using Spellbound within Foxfire for spell check. /forums/images/graemlins/confused.gif
I am not editing a post this is in the original post.
When I got to the end of second line I tried to add the confused Icon to the first line. Put the cursor after the word check, but when I clicked on the Icon it was put after the word post of second line. You may be right. It is a TBN thing when using Foxfire.
Thanks for the changes. Sites are loading faster.
/ Netscape/Firefox tweak #24
Credit where credit is due. Thank JayC for posting the original speedup tips.
Ahh.. I know what you are talking about now with the editing. You weren't talking about plain text. You were talking about the javascript that TBN uses to insert special editing in the post. I DO see the same thing, but I think it is a quirk in the way Firefox handles that javascript in relation to the the input box for the text. I feel that would require a tweak to the code by Muhammad. It may not even be possible to make the behavior exactly the same across all browsers.
No problem. I'm glad the tweak was able to make things faster. /forums/images/graemlins/smile.gif
/ Netscape/Firefox tweak #27
I looked in my Add/Remove programs here on my computer at home and Sun Java is not even in there. However I still can not install from the Fire Fox page or the manual download.
murph
/ Netscape/Firefox tweak #28
Murph:
I'll try and give it another try. E1606 is an online installer error and shouldn't be seen from a full download package. Never seen this before on 10's and 10's of installs. I would try this:
1. Uninstall firefox. I think when you did the intial install back in Dec it was still V.97.
2. Uninstall and/or delete all files you downloaded firefox installer, Java, etc.
3. Reboot.
4. Download the JRE again (See below)
5. Install the JRE before doing anything else. Hopefully it will work this time
6. Download firefox 1.0 and install.
7. Go get the plugins you want/need: Flash, shockwave, QT, etc.
I still am not sure what the problem is especially since you say you have tried it on multiple computers at multiple locations. Lokk for common apps such as anti-virus or the like and turn them off before install and downloads.
Good luck trying again
Regards,
Kevin
JRE
/ Netscape/Firefox tweak #29
Thanks everyone. Getut worked with me last night and got it running. So I am installing today on some of the computers at work today and will give it a try.
Again, thanks for all that helped out.
murph
/ Netscape/Firefox tweak #30
Ok, I ran into this a couple of times today.
What can I do
<font color="blue"> Ok, I ran into this a couple of times today.
What can I do </font>
I get that sometimes, too when I am using Netscape 7.2. The only thing I can think of is a banner ad didn't load right and that is fine with me! /forums/images/graemlins/smirk.gif
/ Netscape/Firefox tweak #32
I could not click on any of the links either as it would just bring up that error. This is on my computer at work. The one at home doesn't seem to bring it up.
murph
/ Netscape/Firefox tweak #33
Murph,
That one may be easier to fix. That site uses javascript to send you to the links. It appears that your machine cached an impartial page load. IE the javascript that handles the redirection never got loaded.
Try this first and see if it fixes it. Browse to the page with the trouble, let it load completely, then hit CTRL-F5. It should attempt a full reload/recache of the page. Try the links. If they work, your good.
If not then: close and restart firefox, but don't browse anywhere other than your default start page. Click on Tools/Options and click on the privacy icon. Click the clear button beside the history section and the cache section. Then browse to the page and try it again.
Let me know if either of those fix it.
Getut
/ Netscape/Firefox tweak #34
Seems to be working today. If I run across another page I will follow your instructions.
murph
1994 GREAT DANE 48' T/A DRY VAN TRAILER (A67714)
1994 GREAT DANE...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
2020 MACK GRANITE DUMPTRUCK (A67714)
2020 MACK GRANITE...
2006 7X12 Lark S/A Enclosed Cargo Trailer (A66738)
2006 7X12 Lark S/A...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
