Needle in a haystack...
/ Needle in a haystack... #1
AHNC
Nevada City CA
Kubota BX 2660 & BX-23
I am pretty good about organizing manuals, but for the life of me, I cannot find my 60" MMM manual for my 2660. I need to remove it so I can beat the heck out of some ground. Any pearls of wisdom for me? As always, much obliged!:confused:
/ Needle in a haystack... #2
Pretty easy actually, rotate casters 90 degrees, set deck height to lowest setting, lower deck, release locking Mecha on front, pull spring pins on lifting arms and raise now disconnect pto shaft, and roll out. Takes less than 5 min. Some use fel to raise tractor to remove pto but I don't think it wise to be under machine supported by hydraulics that could rupture.
/ Needle in a haystack... #3
Forgot, once lifting arms are in raised position set the height control to TOP position.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
GEHL RT14 SKID STEER (A65053)
GEHL RT14 SKID...
