Needing a WHEEL
/ Needing a WHEEL #1
DennisArrow
Platinum Member
Sugar Valley, Ga
Iseki TL 2300, Kubota RTV, Kubota B7610
Developed a crack radiating off of a lug nut on one of my front wheels......Iseki TL 2300........ignored it......should have broken out my welder and ran a bead down the crack.......anyway....was mowing and the wheel gave way.....guess the crack spread a bit more and the next thing I knew the whole wheel had twisted off the hub........ANY ideas for replacement would be totally appreciated.......I will follow up later with exact dimensions......
Right now I know that it uses a 15 inch tire and has a 4 bolt hole pattern........THANKS
/ Needing a WHEEL #2
Dennis, Generally when you see a crack like that in a stress related issue, It would be best to first drill a small hole at the end of the crack to stop the spreading,then weld at your first conveinence ..... Now for a wheel replacement ,try any dealer your close to,They can probably get anything you want or order online? You may even find an implement wheel that would work...Good luck /forums/images/graemlins/smile.gif
/ Needing a WHEEL #3
worst case, get a machine shop to make a new center, and weld to your wheel
(2) TRAILER RAMPS (A62131)
(2) TRAILER RAMPS...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
PAIR OF 2'X6' DIAMOND PLATE RAMPS (A62131)
PAIR OF 2'X6'...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
(INOP) 2023 CRATOS CMX18 ELECTRIC EXCAVATOR (A62129)
(INOP) 2023 CRATOS...
2006 PACE AMERICAN CS714TA2 14' CARGO TRAILER (A62130)
2006 PACE AMERICAN...
