Needing a WHEEL
/ Needing a WHEEL #1
DennisArrow
Platinum Member
Sugar Valley, Ga
Iseki TL 2300, Kubota RTV, Kubota B7610
Developed a crack radiating off of a lug nut on one of my front wheels......Iseki TL 2300........ignored it......should have broken out my welder and ran a bead down the crack.......anyway....was mowing and the wheel gave way.....guess the crack spread a bit more and the next thing I knew the whole wheel had twisted off the hub........ANY ideas for replacement would be totally appreciated.......I will follow up later with exact dimensions......
Right now I know that it uses a 15 inch tire and has a 4 bolt hole pattern........THANKS
/ Needing a WHEEL #2
There is a tractor junk yard in Kevil KY. He says he has grey tractors. 502-462-2191 and Homestead in CA.760-240-1610. I have had good luck with Bob Hey at Hey Wheel in Balwin KS.785-594-3441. He has made wheels for me cheaper than I could buy used OEM. Good Luck.
/ Needing a WHEEL
Reed..........thanks for the help..........I tried the KY number but got a fax or puter........looked at your information and couldnt get YOUR number.......could YOU please send me YOURS and perhaps we can talk about this...........searched the Iseki forum for parts dealers and found about 7........I remeber in the past they were all on one post........anyway.....THANKS
