Need your help
/ Need your help #1
Wayne County Hose
Wayne County Pa.
Massey Ferguson model 85, Allis-Chalmers WD-45
What I need is the following, your tractor make and model, and the max psi and gpm flowing out to your backhoe. I also really need these figures for some mini-excavators too. Thanks for your help, Andy.
/ Need your help
Anybody? I'm ordering a cylinder tomorrow for something I'm trying. If it works, this attachment will be lower priced that anything out there, simpler, and be far less work than anything currently available. I need pressures and gpm figures so I can get a good match of cylinder speed and power.
/ Need your help #3
2001 Kioti DK 35.
Tractor puts out around 7.8 gal/min and 2400 PSI.
The relief valve for my Rhino 85 backhoe is set at 2150 PSI.
/ Need your help
DK35vince said:
2001 Kioti DK 35.
Thank-you, this is a very popular tractor and model. Exactly what I need. Thanks again, Andy.
I need more, and hopefully a mini-excavator or two.
/ Need your help #5
Kubota L5030HSTC
9.8gpm
max system pressure is around 2600
I also have the Rhino 85 but I do not know the relief setting on that.
/ Need your help #6
JD 350B - 23 gpm, 2350 psi
ASV -100 - 38 gpm, 2750 psi hi flow, 20 gpm on low
JD 310 - 28 gpm, 2750 psi
Still trying to figure out how to add a diverter to the 350. KennyD offered to help, but i can't get the schematics to upload :(
/ Need your help #7
John Deere 4300 with a 48 backhoe - 9 gpm at 2500 PSI
/ Need your help #8
B7100HST-D, "new style" from the 90s
1710 PSI
3.1 GPM
I&T shop service manual says these numbers are correct for the following models.
B5100D & E
B6100D & E
B6100HST-D & E
B7100D
B7100HST-D & E
/ Need your help
Thanks guys, for your help. I am working with a friend on an attachment for a backhoe or mini-excavator which is much simpler, cheaper, and much more of a big-time work saver than anything currently available. I can't say what it is yet because we don't want the idea stolen. When you see it, you will wonder why nobody ever thought of it.
/ Need your help #12
Write down dates and drawings on anything you do. If you get crazy enough to patent it those things help. You may never get to that point but it could help you prove you were doing this before someone else took your idea and profited from it.
Jim
/ Need your help
Jim
Already done. I have a friend that's a lawyer. I do hate to admit it sometimes, and I am going to therapy, but sometimes a lawyer is good to have around.
/ Need your help #14
The ratings for my JD2555 and Ford 7710 are as follows as taken from
TractorData.com - information on all makes and models of tractors
JD2555 Hydraulics:
Type: closed
Capacity: 18 gal [68 L]
Total flow: 23 gpm [87.1 lpm]
Outlet flow: 13 gpm [49.2 lpm]
Pressure: 2320 psi [160.0 bar]
Outlets: 1 to 3
Ford 7710 Hydraulics:
Type: open
Capacity: 56 gal [211 L]
Total flow:
Outlet flow: 18.2 gpm [68.9 lpm]
Pressure:
Outlets: 2
/ Need your help #16
Well I do believe that they are real people to at times. And they have their purpose in life. But I have heard rumor that they are full of material that makes them a good fertilizer:eek: So keep at the therapy just in case.........
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2020 Yanmar Diesel Engine (A65579)
2020 Yanmar Diesel...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
