Need V Ditch advice
/ Need V Ditch advice #1
HarleyBob
Puget Sound, WA.
What is the best way to put in V ditch for drainage?
Looking for about 18" deep and 18-24" wide at top.
/ Need V Ditch advice #2
Experienced backhoe operator. The local township did the drainage ditch's along the road on two sides of my property about a year ago. The first day was a inexperienced hoe operator and it was a total mess. 3 foot deep 4 foot wide crater's is what I ended up with. The next day they sent out a experienced hoe operator to do the other side of the road (not mine of course) and he made some perfect looking V shaped ditch's that were about 16-18" deep and 24" wide. Wish they had sent him out the first day when my property was done.
Can't say I have ever seen a V cutting implement. Guess you could make one or even a V shaped bucket for a backhoe. If you had a old hoe bucket you could cut the sides loose from the bottom. Cut the bottom plate to a point and bend the sides in and weld back together to make a pointy bucket. Add some teeth to the sides and you would be V ditching in no time. :)
/ Need V Ditch advice #3
Rock buckets are usually already this shape, but they are mostly (I think) used on larger excavators.
/ Need V Ditch advice #4
You mean one of these tiny little guy's. :)
/ Need V Ditch advice #6
Now if that ain't the neatest gadget I have seen in a while. What do they use to do the cutting? A rotary carbide cutter head?
I need to take this picture over to my local township roads maintenance shop and show it to them. This baby would save them weeks and weeks of work every year.
/ Need V Ditch advice #7
It would make a wider ditch, but a box blade tilted to one side makes a good drainage ditch. Go down one side and back up the other.
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
Ford Tractor (A62613)
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
