Need to rebuild your engine coupler?
   / Need to rebuild your engine coupler? #1
Fitch4123
Terramite T5C
Just got done rebuilding the engine coupler, found all the parts required. listing the part numbers from Neapco but may be crossed reference, they are 1000 series PTO yokes. I measured and found the dimensions at https://www.neapcoaftermarket.com/wp-content/uploads/2019/11/2001ptocatalog637.pdf
Engine/transmission coupler U-joint/ Neapco 1-1071
Center yoke Neapco 10-5303 (1-11/16") / 10-5361 (2.50")/ Dana 10-26-47 ( 2.125")
End Yoke/ Neapco 10-0463 (7/8" hole 1/4" key/ 2.50 L)
Neapco 10-0493 (1" hole 1/4" key / 2.50 L)
Neapco 10-1703 (7/8" hole 1/4" key/ 1-11/16"L)
Neapco 10-1705 (1" hole 1/4" key/ 1-11/16
Danfoss pump shaft seal is NOK 16253-16 replaced it with McMaster-Carr #1199N66 (McMaster-Carr
   / Need to rebuild your engine coupler? #2
Saved, Thanks!
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2372 (A60432)
2372 (A60432)
John Deere 6110M (A53317)
John Deere 6110M...
