Chains Need to change hyd. fluid
   / Need to change hyd. fluid #1
jrghoosier
New Holland TC35
Where are all the hydraulic drain plugs on a TC35? It needs changed. The schematic is too small. Thanks!
   / Need to change hyd. fluid #2
Go to this link New Holland TC-Series Service and it will explain and give you diagrams on how to change your fluid...it is Messicks.com - When you get to that link ...scroll down to find the section on Hydraulic fluid change..
Thanks for the help! Much better than the manual!
   / Need to change hyd. fluid #5
I bought a galvanized 15 gallon bucket from Lowes. Works great and has handles and is low enough you can scoot it under the tractor and have room to remove the plugs.
It is also wide enough you can remove all the plugs at the same time.
Thanks again for the replies.
1604 (A57192)
1604 (A57192)
2013 Audi A6 AWD Sedan (A56859)
2013 Audi A6 AWD...
1999 Triton Boat with T/A Boat Trailer (A55853)
1999 Triton Boat...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2015 Carry-on 8ft. S/A Utility Trailer (A55853)
2015 Carry-on 8ft...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
