Chains Need to change hyd. fluid
   / Need to change hyd. fluid #1
jrghoosier
New Holland TC35
Where are all the hydraulic drain plugs on a TC35? It needs changed. The schematic is too small. Thanks!
   / Need to change hyd. fluid #2
Go to this link New Holland TC-Series Service and it will explain and give you diagrams on how to change your fluid...it is Messicks.com - When you get to that link ...scroll down to find the section on Hydraulic fluid change..
Thanks for the help! Much better than the manual!
   / Need to change hyd. fluid #5
I bought a galvanized 15 gallon bucket from Lowes. Works great and has handles and is low enough you can scoot it under the tractor and have room to remove the plugs.
It is also wide enough you can remove all the plugs at the same time.
Thanks again for the replies.
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2024 Tesla Cybertruck AWD Pickup Truck (A55852)
2024 Tesla...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
