Chains Need to change hyd. fluid
   / Need to change hyd. fluid #1
jrghoosier
New Holland TC35
Where are all the hydraulic drain plugs on a TC35? It needs changed. The schematic is too small. Thanks!
   / Need to change hyd. fluid #2
Go to this link New Holland TC-Series Service and it will explain and give you diagrams on how to change your fluid...it is Messicks.com - When you get to that link ...scroll down to find the section on Hydraulic fluid change..
Thanks for the help! Much better than the manual!
   / Need to change hyd. fluid #5
I bought a galvanized 15 gallon bucket from Lowes. Works great and has handles and is low enough you can scoot it under the tractor and have room to remove the plugs.
It is also wide enough you can remove all the plugs at the same time.
Thanks again for the replies.
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
206320 (A57192)
206320 (A57192)
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
