Chains Need to change hyd. fluid
   / Need to change hyd. fluid #1
jrghoosier
New Holland TC35
Where are all the hydraulic drain plugs on a TC35? It needs changed. The schematic is too small. Thanks!
   / Need to change hyd. fluid #2
Go to this link New Holland TC-Series Service and it will explain and give you diagrams on how to change your fluid...it is Messicks.com - When you get to that link ...scroll down to find the section on Hydraulic fluid change..
Thanks for the help! Much better than the manual!
   / Need to change hyd. fluid #5
I bought a galvanized 15 gallon bucket from Lowes. Works great and has handles and is low enough you can scoot it under the tractor and have room to remove the plugs.
It is also wide enough you can remove all the plugs at the same time.
Thanks again for the replies.
2023 CATERPILLAR 307.5 EXCAVATOR (A51242)
2023 CATERPILLAR...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
4 Drink Hog Waterer (A50515)
4 Drink Hog...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
