Need some sewer line help
/ Need some sewer line help #1
Freds
NW PA
Kubota L3130HST & ZD326s
It looks like I can put my backhoe to good use again. I'm getting my driveway concreted and want to put a sewer line across it for future use. The township supervisor/planner said to come out the cellar wall at the same height my septic line comes out (which comes out a different wall). That would put the future sewer at about 2' below grade at the house. Here's my dilemma, the ground falls away towards the driveway about 2' in 15', then it's level where the driveway is, then falls another foot where I would like to end and cap the line. That's a pretty steep pitch. Around here we run sewer at 1/4" fall in 4' so the liquid doesn't run away from the solids. I'm not sure what kind of pitch to run at, follow the natural grade where it leaves the house, or dig down deeper to try to get a shallower pitch.
I should also mention that I will be crossing an underground electric and phone line. If I stay 2' below grade I will be above it, so even if I am deeper at the house, I should still be above it running a shallower pitch.
And another concern that crossed my mind is if I run at the steeper pitch, won't that mess with me trying to elbow up inside the house and be plumb? Do you use a fernco ftg there to allow some flex so your vertical drop can be ran plumb?
Lots of questions, I know. But I know where to go for sound advice. So what do the plumbers here think?
Thanks
/ Need some sewer line help #2
Freds, Mornin'. You going to city sewer or a septic tank?
Around here, you put your septic tank close to the house. 15 feet or so. Then the clean water can run to the drain field where ever it has to. Even using a sump and pump to run it uphill.
City sewer is a different deal. The city will tell you how to do that. Dave
Mornin' Dave.
The "city" said to run the pipe out of my basement at the same height the septic was at, then get it across the driveway. I believe my situation is a lot more relaxed than what you might think.
It is for future sewer that is supposed to be going in within the next five years so I don't have to tear up my driveway, which is being poured the end of this week.
/ Need some sewer line help #4
I would maintain your 1/4", then use 45's to step down your sewer line as needed, you made need to do several times to your capping off point.
hth
/ Need some sewer line help #5
If my memory is right, you can have your sewer lines range from 3 to 8 degrees of slope. While too much angle is said to cause the fluids and solids to seperate, that's based more on the older clay pipes than modern PVC pipe. I wouldn't worry about going a bit steeper on your slope if it wasn't too rediculous.
Using 45's and 22.5's to drop down quicker will also work, just be sure to use Schedul 40 for all of it, including the pipe. I don't think the cost savings is worth it to use thin wall drain pipe.
Once you get your pipe past the house, put in two sweeping T's that will allow you to access and snake out the drain lines. The T's go in so that they angle towards each other so if you don't have any dead areas that you cannot get to.
Eddie
/ Need some sewer line help #6
1/4" in 4' is the correct fall.
Have they done the engineering work for the future sewer? How do you know how deep it will be? I'd be very hesitant to run the line from the house without knowing how deep the main will be.
Once the sewer main is installed why don't you just cut the line going to your septic and tie it to the main? That's how it's usually done.
I appreciate all the input.
The 45's to tier down was a great idea. I was thinking the pipe should be a straight section. Which might be preferred, but not necessary.
Thanks for the PVC vs clay advice and the range of pitch Eddie.
Pops, the main at the road will be 8-1/2' deep. I don't want to tie in to the existing septic line outside because I can't get my tractor into that area without having to take down fencing, and it would mean a lot more trenching outside following alongside the house fairly close. It would be a trickier dig as I'd have to angle the tractor in.
And I'd just as soon have all new pipe anyway. I don't like the way any of these drains were run in the house and the toilet currently raises before it drops. Running all new will let me run them the way they should be run.
/ Need some sewer line help #8
You do not have to worry to much about the pipe being too steep. What one flush leaves behind the next must move. You do want the pipe to be as straight as possible or else in the future when a clog does occur you will most likely end up digging. There are very few sewer cleaning heads on the market that will go around a 4" PVC bend. A snake or eel will go around the bend but are less effective than a high pressure cleaner.
Most utilities will require gasketed SDR 35 pipe for your lateral. Be sure to lubricate the gaskets with pipe lube or dish soap. I would recommend putting the pipe inside of a casing under the drive way and sealing both ends of the casing with a boot. Just incase you need access in the future.
/ Need some sewer line help #9
Question for you. Are the septic fields in the area beginning to faiil? Is that why the city is planning a sewer line. You might want to keep your septic if you can because the city will charge an arm and a leg for the privilege of hooking up to their sewer line and the rates just continue to go up. Just trying to save you some time and money.
I don't know about that SDR pipe, HF. The township just said 4" sch 40.
It's not an arguable situation Rick. When they come by with the main, you are required to hookup. Working septic or not. There are a few townships around that tried to band together and fight it, but couldn't. It's an EPA thing.
/ Need some sewer line help #11
SDR 35 and Sch 40 are usually the two alternatives. I agree with EddieW if you use fittings use the same schedule as the pipe. You may want to ask the utility if they want to inspect prior to closing the ditch and put a Y and 45 for a clean out at your house and at the point of connection to the city system. Good luck
/ Need some sewer line help #12
Most areas around here they require sch35 pipe also you will need a clean out and a vent right at the house along with a clean out at least every 100ft and maybe closer that that depending on there spec and DEP. There will also have to be a inspection port right where your line connects to the main. In the 3 county area I work in i have never saw any sch 40 pipe used. Also the pipe has to be green in color!! That is state wide I believe because when we run the camera in the pipe to check for leakage or breaks all you get with white is a glare think of a bad snow storm.
/ Need some sewer line help #13
I have heard the 1/4" per foot slope (which works out to 1.2 degrees) also, but can tell you from experience that I lived for 35 years in a house where we had a 150' sewer line which followed the contour of the downhill slope to the main sewer.
The slope varied from plumb to 1/4" per foot, with about 60' at ~35 degrees. Some cast steel sections, some ABS plastic.
The only problem we ever had in that entire time was a root plug in the county-maintained section.
I used to think slope mattered, and bought into the liquid outrunning the solids story, but after that experience, I don't think matters very much as long as it is downhill.
The real reason is that it is humid in the sewer pipe and nothing ever dries out enough to block the water from the next flush. Running the clothes washer dumps a lot of soapy water down the pipe which flushes stuff out.
/ Need some sewer line help #14
Around here septic systems call for a mininum fall of 1/8" per foot, and there is no max specification. Personally, I'd rather go steeper than too shallow.
Thanks for the additional info guys. My email notification must have quit working...
It started out 1/4" in 4' pitch, but then it got a little steeper. Around 3/4 to 1" in 4'. I think I'll be OK. And I did use 2-45s to step it down when I came to the driveway. It finished 38" below grade, which should give me plenty of drop when it comes time to run it to the road where they'll be 8-1/2' deep. I was pretty happy with that depth considering the ground was falling away. I'll put my cleanout in at that time. Right now I just capped the pipe (not glued of course) and set a 4x4 post in front of it cut flush with the ground. That should give me a good surface to dig against when it comes time to find it and trench again.
The guy at the town hardware store said everyone runs 4" drain for sewer around here, the kind with the flared ends like drain tile. When the time comes for the line up to the road I'll double check what the township wants me to use, or if I can even do that part myself, but the line under my new driveway is done anyway :)
I just had time for one pic with my cell phone.
