Need some hydraulic advice
/ Need some hydraulic advice #1
Nklpltd
Logan, UT
None
Hey guys I need some advice.
I realize this is a tractor forum, but hydraulics are hydraulics and I just need some general advice for a future project. My question is about a truck mounted crane. Like on most tractors or cranes, the controls are all by lever.
I am looking at buying a crane for home use and to help with the build of my future house next year. I will be building myself when I have extra time, so this means usually working alone. For my uses that I need the crane for, I will usually need a second person to help guide whatever I am lifting, if I am stuck on the truck with the lever controls. Well I want to try and convert to radio control or at least electronic toggle control with a long cord so that I can do this alone if possible.
My main question to you guys is, what type of distribution block am I looking for? It appears to be a pretty simple swap if I am only going to toggle control. swapping the block and wiring the switches.
Any advice will be greatly appreciated.
Thanks
Jake
J J... Thanks, that is an awesome source.
I looked at they have a 16 function remote which would be perfect.
That's was one of my biggest questions was using solenoid valves.
Would a crane use center open, closed or float?
/ Need some hydraulic advice #4
Depends on who's crane you get, most all of the units I have worked on are open center units. All the way from pickup mounted Auto cranes to 24 ton truck mounted units. Even the Grove units were open center. CJ
/ Need some hydraulic advice #5
Electric control of valves is typically on - off and would provide a very erratic or jerky movement on a crane. Using proportional control will provide the infinite speed control but will also add significant cost. Companies also make mobile style stack valves that can have manual lever control and proportional control capabilities.
/ Need some hydraulic advice #6
oldnslo beat me to it. So I will add my voice to what he is saying. You need to specifically look for a setup that is proportional. Or use a proportional remote control setup with servos motors connected to the hydraulics... but I am not suggesting that.
Wow that is all great information. It really gives me a lot better direction to research. I really appreciate all the help.
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
