Need some help with a sprayer
/ Need some help with a sprayer #1
PumpingPete
Fort Scott, KS
New Holland Workmaster 55
Hi all, I need some help with a recently purchased sprayer. It started out as a good deal and has quickly gone downhill. I filled the original tank up with water and as I was pulling it out to my land, the side of the tank busted open. Good news is that my neighbor won't need to water anytime soon. Bad news is that I had to buy a new tank. Ok, here is where I need someone's help. The new tank I bought has one outlet pipe on it. The other had two. I am using a delevan pto pump. Is this going to be an issue? I am a little confused as why there was two pipes on the original as the hoses were all disconnected when I picked it up. Any help is appreciated.
/ Need some help with a sprayer #2
For a spray tank you really only need the following:
1. Sump for the product to be pulled into the pump.
2. Vent to allow air in as product leaves.
3. Bypass or agitation to relieve pressure that is not needed to maintain a rate for a given speed.
If for some reason the sump is not large enough to allow adequate flow to the pump, there may be a need to use two sump valves to get the required flow.
Thank you for your quick answer.
2022 EZ-GO ELITE...
2008 Ford F-350 4x4 Crew Cab Emergency Service Truck (A64556)
2008 Ford F-350...
2016 BMW X3 AWD SUV (A64557)
2016 BMW X3 AWD...
2025 TopCat ECSSSTG200 Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 TopCat...
2016 Nissan Versa Sedan (A64557)
2016 Nissan Versa...
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
