Need some 4110 assistance...
/ Need some 4110 assistance... #1
Keith_B
Platinum Member
Kentucky
Mahindra 4110
...I was out pushing and clearing more brush yesterday and in the middle of the bramble was a downed 6" tree. The edge of the tree's limb must have caught the level indicator rod on the bucket and bent it without my noticing it. When I went to curl the bucket I bent the rod nearly double. I figure the easiest way to get it fixed would be to just get a metal rod and have it welded on and paint it red. The only problem is that the rod is in such poor condition I don't think I can get an accurate measure. Can anyone help me out by giving me the measure of the length of the rod?
/ Need some 4110 assistance... #2
Seems to me, the only measurement you need is the diameter of the rod. Put the loader down, bucket flat on the ground and take a measurement from the spot the rod hits the bucket to the top of the indicator tube. Buy some rod several inches long, install on the bucket and cut it off where it sticks out of the indicator tube.
Simple!
/ Need some 4110 assistance... #3
Keith,
I did the same thing a while back, not sure if I bent mine as bad as you describe. My solution was to take the level indicator assembly off the loader, pull the rod out, and bend it straight using the toothbar on the bucket as leverage!! Worked great for me and you can hardly tell it was ever bent. Those things do stick out in a vulnerable position.
Basically I just had to remove the 2 bolts that hold it on, bend it straight, and put back on. Took about 15 minutes..
Yours might be bent beyond repair though based on your description.
</font><font color="blue" class="small">( Keith,
)</font>
I don't think I can straighten mine enough to put it back in service.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 John Deere 6105D (A64126)
2014 John Deere...
