Jan 26, 2017 / Need Shaft Assy for FEL - L245DT #1 T Tractorbill New member Joined Sep 22, 2007 Messages 14 Location Alexandria Twp, NJ Tractor Kubota L245DT I'm in need of a shaft assy for FEL part #70050-01113. It is the back half that slips over the crankshaft on L245DT. Or what other options to keep this FEL working would be appreciated. Attachments Shaft Assy 17.pdf 30.9 KB · Views: 150
Jan 28, 2017 / Need Shaft Assy for FEL - L245DT #2 D Dave M7040 Elite Member Joined Dec 10, 2012 Messages 2,757 Location Williamstown Ontario Canada Tractor Kubota M7040 Nuffield 465 Most farm equipment use a standard spline fitting. However, there are many depending upon the size, etc. What has gone wrong? Splines stripped or part(s) lost? Can you post a couple of photos of the front of the engine where I assume there is a male spline the red circled part slips over. Do you have a caliper with which you could measure the diameter of the male part in mm. It does not have to be an expensive one. Here is a caliper for $15 from Northern Tool Ironton 6in. Stainless Steel Digital Fractional Caliper | Calipers| Northern Tool + Equipment Dave M7040
Feb 12, 2017 / Need Shaft Assy for FEL - L245DT Thread Starter #3 OP T Tractorbill New member Joined Sep 22, 2007 Messages 14 Location Alexandria Twp, NJ Tractor Kubota L245DT See attached photos Thanks for your help Attachments IMG_1520.JPG 1.6 MB · Views: 81 IMG_1518.JPG 3.1 MB · Views: 73 IMG_1516.JPG 937.6 KB · Views: 64 IMG_1512.JPG 1.2 MB · Views: 108
