Need Shaft Assy for FEL - L245DT
   / Need Shaft Assy for FEL - L245DT #1
Tractorbill
Alexandria Twp, NJ
Kubota L245DT
I'm in need of a shaft assy for FEL part #70050-01113. It is the back half that slips over the crankshaft on L245DT. Or what other options to keep this FEL working would be appreciated.
  • Shaft Assy 17.pdf
   / Need Shaft Assy for FEL - L245DT #2
Most farm equipment use a standard spline fitting. However, there are many depending upon the size, etc.
What has gone wrong? Splines stripped or part(s) lost?
Can you post a couple of photos of the front of the engine where I assume there is a male spline the red circled part slips over.
Do you have a caliper with which you could measure the diameter of the male part in mm. It does not have to be an expensive one.
Here is a caliper for $15 from Northern Tool
Ironton 6in. Stainless Steel Digital Fractional Caliper | Calipers| Northern Tool + Equipment
Dave M7040
See attached photos
Thanks for your help
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
JOHN DEERE TS LOT NUMBER 151 (A53084)
JOHN DEERE TS LOT...
New/Unused AGT MX-CRT23 Mini Skid Steer Loader (A51573)
New/Unused AGT...
New Long Forks (A53002)
New Long Forks...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
