Need replacement for Stihl ms241
/ Need replacement for Stihl ms241 #21
Does it stop as in gets hard to turn by hand or locks up so tight you cannot turn it with a wrench?
Don't do that. It could do more damage. If the piston stops there is something keeping it from moving. Debris from a broken bearing, a piece of broken piston ring, piston ring hanging up in a port, etc. I'm assuming the spark plug has been removed so it's not running up against compression.
Did you take the muffler off and look in the exhaust port as you gently turn the crank? Pistons usually seize on the exhaust side because it's hotter.
I did remove the spark plug, but it made no difference. I have not tried a wrench on it. I won't have a chance to pull the muffler and have a more careful look until Sunday or Monday. I still work in Seattle during Tuesday -Saturday, and my wife and I go up to our property in Snohomish, about an hour's drive, most Sundays and Mondays. That's where my saws live, along with the tractor, the chipper, the ztr, etc.
I truly appreciate all the advice and encouragement! I'll keep you posted.
/ Need replacement for Stihl ms241 #23
It should spin easily with the spark plug out. As I’m sure you are well aware something is wrong.
/ Need replacement for Stihl ms241 #24
My 241 has seized up and apparently died, so I am thinking about what to get next. I also have a new 261cm with 20" bar (I sold off my 291 after buying it), and an older 211 with a 16" bar. The 211 is a little wimpy, and I dislike the toolless chain tightener. (It is wearing out, and is hard to use when it's dirty or I'm wearing gloves.) The 261 is a great saw, lighter and more powerful than the 291, and pretty much as big as I need.
I still want a better smaller saw in the 40cc range for limbing and pruning. The 241 has a compression release, which I like. The 250, which I'm thinking about, doesn't, and I see both good and bad reviews of it.
Any suggestions? I am used to Stihls, and I'd like to stay with them. We have 11 acres of mostly rainforest, some of it jungle, in western Washington.
I’m in the forests of western Washington too.
If you’re looking for a lightweight reasonably powerful saw, I’d recommend the MS 194 C.
It’s my favorite saw and I use it more than any of my other chainsaws.
Mike
Okay, so I am making some efforts on the 241. I've got the covers and the muffler and the sprocket off. Nothing wrong with the pull cord setup. I have tried the various strategies to get the flywheel off without a puller, but it's stubborn. Will order a puller. The piston does not appear scored.
The current state of affairs is that with the muffler off and the sparkplug out, I can rotate the flywheel by hand 180 °, and then it stops. I can rotate it backwards, but only the same 180°. I can see the piston go up and down with it. And I will probably be able to eventually get the flywheel off...but then what? I don't know what damage or problem I'm chasing.
In the meantime, i have gone back to my old ms211 with 16" bar for light work like limbing, plus the 261 with 20" bar for bigger stuff. I have looked up specs on the various suggestions you all have been kind enough to give, but I still hope that I can resurrect the 241, and therefore not have to buy something new.
/ Need replacement for Stihl ms241 #28
Funny, I have no recollection of how I got the flywheel off my MS 250 when I rebuilt it. It couldn’t have been to hard and I didn’t use a puller. I just watched a video, I think you just use a punch and hammer on the crank and the shock pops it loose.
Why it won’t turn freely is a mystery to me. It almost sounds like something on top of the piston. If you had a bad rod or crank I’d think you’d hear grinding sounds or something. I suppose something could also be in the crank case jamming it. Let us know what you find.
/ Need replacement for Stihl ms241 #29
You can remove the cylinder and head (they're one piece on saws unlike motorcycles). Pro Stilhls usually take a long T25 bit for the cylinder bolts which you can access through holes or cutouts in the fins. With the cylinder off you can inspect the piston and cylinder fully. Before removing the cylinder look into the intake and especially exhaust ports. Check that the rings are intact.
Sometimes you can feel or hear the location where the blockage is and narrow it down. Does it feel like a solid stop or more of a crunch one?
/ Need replacement for Stihl ms241 #30
T27 green handle one in this brand at bottom right. For stihl.
I'm having an Aha! moment...maybe.
I remembered that when I tried to pullstart the machine, I pushed in the decomp valve as usual. But then, even though it wouldn't start, and got stuck, the valve button popped out. So something is wrong with the valve. A few minutes studying at YouTube University yielded a video describe just this
I had an aha moment. When I tried pullstarting, I pushed in the decomp valve as usual. It popped right out even though there was no start. I found a YouTube video describing a similar situation, in which part of the valve fell off and into the cylinder. Maybe that's what keeps the piston from moving. If I can get to our property where the saw lives, I will look into this. Lots of snowy, icy, hilly roads between here and there.
If that's it, the first thing is to extract the debris, and the second is to figure out what damage has been done. Getting a replacement valve and screwing it in should be simple.
Sorry for the repeat. Sent the first one without meaning to.
/ Need replacement for Stihl ms241 #34
Your posts have almost motivated me enough to once again tinker with my unusable due to it being unreliable 270c 👍
/ Need replacement for Stihl ms241 #35
Stihl and afm decomps known for this.
Why I always try to keep husky decomps on hand.
Hmmm. Decomp valve is dirty, but appears okay. No apparent debris above piston, either. I have the clutch off, too. Nothing looks weird there, either. I guess the next step is to get a long t27 bit and take off the head. I hope I remember how it all goes back together. Anybody know where to download the workshop manual for free?
And oh boy, now the decomp valve on my 261 is popping out every time I pull the starter rope, even though it doesn't light off. What is going on? Are my machines going on strike?
/ Need replacement for Stihl ms241 #38
Stihl valves sometimes do that. I have one that does. Some people drill out the outlet hole but a Husqvarna valve, which works better, does not cost all that much.
PM sent on the manals.
/ Need replacement for Stihl ms241 #39
When I rebuilt my MS250 I took a bunch of pictures but Eric sent me a manual also which helped a lot. I have a MS 261 and the decomp valve pops up after most pulls of the rope even if it doesn’t start. I forget to use it half the time, it doesn’t really pull that hard not using the decomp valve.
/ Need replacement for Stihl ms241 #40
I would love to revive the 241. I wonder why they stopped making it.
I heard not enough sales. Too close in weight (as mentioned and shown by xyz123) to an MS261 gen 2. I have a gen 1 MS261 and was ready to buy a 241 when I heard they were pulling it. I stuck with my top handle for limbing or just use the 261.
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Toro Reelmaster 5400-D 100in Commercial Fairway Reel Mower (A59228)
2001 Toro...
TANK MANIFOLD (A58214)
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
