Need replacement for Stihl ms241
   / Need replacement for Stihl ms241 #11
They are pretty simple to rebuild. It always seems intimidating but it’s really not. This is most of the parts from when I rebuilt my MS250. Eric on this board helped me some picking out higher quality parts. I spent much more time cleaning oil and saw dust off than actually taking it apart and putting it back together.
   / Need replacement for Stihl ms241 #12
If you liked your 241 bar and chain set up switch it over to your 261. If you have a older Gen 1 261 it will be heavier saw. But if Gen 2 or 3 it will be light like the 241.
Gen 2 261 in pic when they went lighter. Can tell by clutch covers and slant fins by quick look.
   / Need replacement for Stihl ms241 #13
You have to make sure bars and chains are compatible. I know the 18“ chains for my 250 won’t work on my 261. I think the bar is a little taller on my 261 but I’m not sure.
   / Need replacement for Stihl ms241 #14
241 261 basically same saws. Can swap all B+C rim drum etc from 241 to 261.
Your 250 plastic saw is totally different mount.
   / Need replacement for Stihl ms241 #15
There's a ton of more knowledgeable folks on chainsaws, but I have 4.5 or 5 depending how you classify cordless, saws that still work A Stihl Ms 311 20" hands down amazing saw for bigger stuff, an old lighter craftsman with 18" bar I use for limbing, both are up north used a few times a year limbing and felling trees for making wood, downstate I use a DeWalt 20volt (wife uses it extensively) its unfortunately not a true top handle, a 20 volt DeWalt pole saw thats not the best balanced especially with extension on it but one of my favorites is my newer echo CS 400 18" bar that replaced a unreliable nightmare 18" Stihl 270c I believe, I'd take it apart get it running great on my workbench a week later I'd take it out to use and nothing 🤬. The echo is light and well balanced powerful enough for small/ medium stuff, priced right, more importantly its reliable always starts and runs like it's supposed to. My dad used to be an echo dealer and still has a 35 yr old 16" echo thats survived a ton of abuse. For me anyway weight, durability/reliability are important depending on what I'm doing.
Well, after these comments I am emboldened to at least disassemble the old 241 to find out what went wrong. So far I have had time only to take off the various covers, including the starter. When I try to turn the flywheel by hand, it turns easily one-half revolution in either direction, then stops. Does this suggest anything? I won't have a chance to work on it until later in the weekend.
   / Need replacement for Stihl ms241 #17
Does it stop as in gets hard to turn by hand or locks up so tight you cannot turn it with a wrench?
   / Need replacement for Stihl ms241 #19
I'm glad you're talking a crack at it.👍
Between some forums and YouTube you almost have nothing to loose.
I was going to suggest at least get an estimate from someone who doesn't sell saws then reccomend looking at an Echo, a much more reasonably priced saw of equal reliability and reputation. This from a guy with a half dozen or so Stihls.
   / Need replacement for Stihl ms241 #20
View attachment 771100View attachment 771101
I agree. The smaller Stihls are not really problem to take apart
I rebuilt my 250 when the plastic caged bearings let go.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
SKID STEER ATTACHMENT MULCHER (A58216)
SKID STEER...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
20ft Shipping Container (A57453)
20ft Shipping...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
