Need pneumatic control expert advice.
/ Need pneumatic control expert advice. #11
hmmmm. another solution.
have a "float" neutral. which means when you aren't pushing on the lever, the pressures on both sides are zero.
whatever you are actuating, add friction. For instance, two steel plates sandwiching another steel plate with threaded bolts to apply pressure. then, it doesn't move unless external pressure is applied. only thing is it might be kind of "jerky".
just trying to learn.....
CFG Industrial MX12RX (A60463)
CFG Industrial...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
1998 FORD F-150 SINGLE CAB TRUCK (A59823)
1998 FORD F-150...
