need opinion on JOHN DEERE 5210
   / need opinion on JOHN DEERE 5210 #1
wasatchcomm
none currently
is this a good cold weather tractor? I live at 7300' Wyoming, I read a review somewhere that these are not good in cold weather as far as the shifter, new to tractors but I found a really good looking tractor with 1300hours $27k. any advice would be appreciated
   / need opinion on JOHN DEERE 5210 #2
Shifter?
You mean for starting in cold weather? Can it be retrofitted with a block heater? Most can. If you have an electrical source nearby, it should make starting much easier. There are other cold starting aids available, too.
this is what I read
John Deere 5210
Model Year: 2001
JD 5210 with front loader. Tractor has been good for my uses, bush hogging, land clearing, loading and unloading trailers. Some plowing and light farming.
Pros: Has plenty of power for the size.
Cons: When freezing temperatures hit it's useless. Shifter freezes and can't be moved.
ive also read a few complaints about the cab and fitment and what not
   / need opinion on JOHN DEERE 5210 #5
OK, I thought maybe your computer self corrected “starter/starting” into “shifter”. (y)
Wonder if the complainer had got water into his transmission and it was freezing up?
ya thats what I was thinking,,, seems like it should be correctable, but we get -40 here and that is a problem, we have winter 7 months of the year here,
   / need opinion on JOHN DEERE 5210 #7
I have read that some of the 5 series JDs get water in the shifter boot which freezes and prevents shifting. Some have taken the plate off the bottom and drilled drainage holes to prevent it. Here's a link to some discussion about it:
frozen shifter
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
Front End Loader Fork Attachment 20,000 lbs 5 foot (A59213)
Front End Loader...
