need opinion on JOHN DEERE 5210
   / need opinion on JOHN DEERE 5210 #1
wasatchcomm
none currently
is this a good cold weather tractor? I live at 7300' Wyoming, I read a review somewhere that these are not good in cold weather as far as the shifter, new to tractors but I found a really good looking tractor with 1300hours $27k. any advice would be appreciated
   / need opinion on JOHN DEERE 5210 #2
Shifter?
You mean for starting in cold weather? Can it be retrofitted with a block heater? Most can. If you have an electrical source nearby, it should make starting much easier. There are other cold starting aids available, too.
this is what I read
John Deere 5210
Model Year: 2001
JD 5210 with front loader. Tractor has been good for my uses, bush hogging, land clearing, loading and unloading trailers. Some plowing and light farming.
Pros: Has plenty of power for the size.
Cons: When freezing temperatures hit it's useless. Shifter freezes and can't be moved.
ive also read a few complaints about the cab and fitment and what not
   / need opinion on JOHN DEERE 5210 #5
OK, I thought maybe your computer self corrected “starter/starting” into “shifter”. (y)
Wonder if the complainer had got water into his transmission and it was freezing up?
ya thats what I was thinking,,, seems like it should be correctable, but we get -40 here and that is a problem, we have winter 7 months of the year here,
   / need opinion on JOHN DEERE 5210 #7
I have read that some of the 5 series JDs get water in the shifter boot which freezes and prevents shifting. Some have taken the plate off the bottom and drilled drainage holes to prevent it. Here's a link to some discussion about it:
frozen shifter
2023 Kubota L6060HST Compact Utility Tractor (A56438)
2023 Kubota...
Pallet of 10 Chains and 5 Binders (A57454)
Pallet of 10...
2024 Yakta YXR610 Zero Turn Lawnmower (A57453)
2024 Yakta YXR610...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
