Need new Tread Material (where feet go on tractor "floor")
   / Need new Tread Material (where feet go on tractor "floor") #1
bigroccrek
Pearblossom Ca
TC29D & 1952 Ford 8N
Hi all,
I have a 2002 New Holland TC29 and the anti-skid material (where you feet go) is worn out. I went to the most local New Holland dealer (about 60 miles away) only to discover they have gone out of business (I was going that way anyway). I have looked on line for replacement material hopefully cut to fit since the old stuff is trashed, no luck. Any ideas where I might find this tread material? I have searched on-line but no luck.
Thanks.
   / Need new Tread Material (where feet go on tractor "floor") #2
If your tractor isn't a show tractor, maybe cutting up something like this and gluing it together might be a inexpensive, easy and effective solution: Anti-Fatigue Foam Mat Set, 4 Pack. I have used this matting for quite a few things beyond it's intention.
Thanks! Not a show tractor. I was really looking for something anti-skid like it came with, just a thin material that I can put on with adhesive. Thanks again!
   / Need new Tread Material (where feet go on tractor "floor") #4
most any hardware store or home improvement store should have a version of it
HomeDepot
HomeDepot
Thanks. I did look at the material at Lowes and HD but it only comes in a 4" strip. If I could find a 4 foot by 4 foot piece I can cut to fit but so far no luck. Really don't wnat to piece it together using 4" strips.....but if I have to I suppose I will. Gotta believe somewhere out there is a sheet of material.
   / Need new Tread Material (where feet go on tractor "floor") #6
OK, you said you wanted something thin, but...
I bought horse stall padding at Tractor supply. Comes in 4 X 4 ft square.
It is HEAVY duty (use for horses) but sounds like it may work.
Good Luck!
   / Need new Tread Material (where feet go on tractor "floor") #7
I cut up a 4' x 5' non-slip entrance rug. It is thin carpet on top and rubber on the back.
   / Need new Tread Material (where feet go on tractor "floor") #8
Padding and rubber will trap moisture and make a rust spot
   / Need new Tread Material (where feet go on tractor "floor") #9
   / Need new Tread Material (where feet go on tractor "floor") #10
Every 2 or 3 years I paint the floorboards and other stepping surfaces with Rust Oleum paint, then put some dry sand in a large salt shaker and sprinkle generously on the wet paint. When it's dry, brush off the excess. Been doing this for years on both tractors and the mini-excavator......Dan.
Adams 6 Ton Hydraulic Lime Spreader (A55302)
Adams 6 Ton...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2021 Chevrolet Tahoe SUV (A55758)
2021 Chevrolet...
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50775)
2020 Case TV450B...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
