Need new Tread Material (where feet go on tractor "floor")
   / Need new Tread Material (where feet go on tractor "floor") #1
bigroccrek
Pearblossom Ca
TC29D & 1952 Ford 8N
Hi all,
I have a 2002 New Holland TC29 and the anti-skid material (where you feet go) is worn out. I went to the most local New Holland dealer (about 60 miles away) only to discover they have gone out of business (I was going that way anyway). I have looked on line for replacement material hopefully cut to fit since the old stuff is trashed, no luck. Any ideas where I might find this tread material? I have searched on-line but no luck.
Thanks.
   / Need new Tread Material (where feet go on tractor "floor") #2
If your tractor isn't a show tractor, maybe cutting up something like this and gluing it together might be a inexpensive, easy and effective solution: Anti-Fatigue Foam Mat Set, 4 Pack. I have used this matting for quite a few things beyond it's intention.
Thanks! Not a show tractor. I was really looking for something anti-skid like it came with, just a thin material that I can put on with adhesive. Thanks again!
   / Need new Tread Material (where feet go on tractor "floor") #4
most any hardware store or home improvement store should have a version of it
HomeDepot
HomeDepot
Thanks. I did look at the material at Lowes and HD but it only comes in a 4" strip. If I could find a 4 foot by 4 foot piece I can cut to fit but so far no luck. Really don't wnat to piece it together using 4" strips.....but if I have to I suppose I will. Gotta believe somewhere out there is a sheet of material.
   / Need new Tread Material (where feet go on tractor "floor") #6
OK, you said you wanted something thin, but...
I bought horse stall padding at Tractor supply. Comes in 4 X 4 ft square.
It is HEAVY duty (use for horses) but sounds like it may work.
Good Luck!
   / Need new Tread Material (where feet go on tractor "floor") #7
I cut up a 4' x 5' non-slip entrance rug. It is thin carpet on top and rubber on the back.
   / Need new Tread Material (where feet go on tractor "floor") #8
Padding and rubber will trap moisture and make a rust spot
   / Need new Tread Material (where feet go on tractor "floor") #9
   / Need new Tread Material (where feet go on tractor "floor") #10
Every 2 or 3 years I paint the floorboards and other stepping surfaces with Rust Oleum paint, then put some dry sand in a large salt shaker and sprinkle generously on the wet paint. When it's dry, brush off the excess. Been doing this for years on both tractors and the mini-excavator......Dan.
2011 Ford Ranger (A53314)
2011 Ford Ranger...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A56129)
2007 FREIGHTLINER...
HD4 4' Blade Brush Cutter (A53316)
HD4 4' Blade Brush...
Toro 880 Procore Turf Aerator Tractor Attachment (A55787)
Toro 880 Procore...
(2) Plate Compactors (A53316)
(2) Plate...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
