Need new Joystick
/ Need new Joystick #1
Taktiks
Evergreen Park
Branson 2400 HST
Have two Branson 2017 2400H tractors. One has a skid steer quick attach and the other does not. The SL00 quick attach has a joystick with cables to the valve below. The cables keep sticking. Disassembled, cleaned, and lubed a few times and am still having issues. I would prefer a joystick/valve combo (like my other tractor) and was wondering if anyone replaced their joystick with a reasonably priced generic one, hopefully with float.
/ Need new Joystick #2
/ Need new Joystick
I have not but will. Is it just me but isn’t a combined joystick/control valve simpler and therefore more reliable than cable operation?
/ Need new Joystick #4
Cables can require more maintenance and or adjustment vs mounted joystick but base valves are typically very similar if not the same.
/ Need new Joystick #5
The cable/valve setup is easier to locate and place for the manufacturer.
/ Need new Joystick #6
Many of the cables are standard morse cables. I never figured out how to ID the different series though.
On a Kubota M108S I replaced a jury rigged setup using components from Buyers Products.
I used their B206305 dual axis joystick.
I mounted the joystick then measured and bought the cables.
For simplicity I bought it all off Amazon. I did have to drill the bulkhead holes out larger on the loader valve mount for the bulkhead mounting of the cable sheath. The Buyers cable have 1/4"-28 threads on the cable/rod and 3/4"-16 on the sheath. If you remove your cable and do some measurements you can see if it would work or not. If not they sell a few cable connection kits that might work.
Hope this helps!
I do not like the valve in the cab as it makes the cab darned hot and its louder. The cables are a pain and require maintenance, but are much nicer in my opinion.
/ Need new Joystick #7
The rocker plate is broken, which would be the cause of your sticking.
/ Need new Joystick
Hope this helps!
Thanks for thorough reply.
/ Need new Joystick
I saw a combined unit at Vevor. Is it worth a shot? But on my second 2400H its valve has the capabilities on the decal. Would Vevor’s do this?
/ Need new Joystick #12
The Vevor valve should do everything your current valve does. Check the specs for "Float", but if it is for a loader situation, then it does. Vevor products are very inexpensive Chinese products. From what I have experienced, they perform as expected, but don't expect to get parts is needed.
Also, you probably have to change your plumbing to accommodate the Vevor valve.
/ Need new Joystick
If you had to replace your loader valve do you have a preference?
/ Need new Joystick #14
If you end up going with a new valve, make sure you get the correct power beyond sleeve for that valve you get.
/ Need new Joystick
I don't have a Branson, but have you looked at Surplus Center?
I believe this is what I need. I wonder if it is vastly better than a cheapie from Vevor?
/ Need new Joystick #16
May be the same valve, but that will work.
/ Need new Joystick
Sorry for the delay. I did purchase a rocker plate and am thinking of buying cables too, before I go the whole joystick route. I am not at the tractor's location, but are there "stand-sized" cables as I cann ot find specs on the length of the ones I have.
If all that fails, I would go the combined JS/valve and deal with new hoses as they are weathered. The Surplus unit looks good. No idea about thread compatibility. Any other suggestions? I will call Scott, the Service Director in Rome, Atlanta, but he can be hard to get a hold of.
By the way, does anyone know if a Peruzzo Flail mower will fit a Harbor Freight quick attach?
Thank you
