Need info about lathe bits
/ Need info about lathe bits #21
To answer the question at hand, I make my parting blades out of broken hacksaw blades. I grind the teeth off of the edge and then grind whatever shape I want on the cutting face, including tapering the sides if needed. I always have new stock when one breaks.
But, I have concerns over your plan to cut through 3/16" metal with one tooth. You'd be far better off using a rotary cutter. I know of an electronics shop that cuts all of their panels on an engraving table. Even with a carbide rotary engraving bit, it is pretty s-l-o-w because of the multiple passes (and they cut only plastic and aluminum panels).
I've found that a Sawzall is about the best you can get for a wide variety of cutting needs, so perhaps you can find a used one at the flea market.
Good luck!
- Just Gary
I was in Lowes today killing time
and I noticed they had mapp/oxy torches with disposable tanks for $50.
I think I'll get one of them. can also use propane.
No more stuff than I do it should work great.
But I'm gonna post a seperate question about it to get opinions.
Pooh Bear
/ Need info about lathe bits #23
Bear you're not going to cut steel with disposable bottled gas from Lowe's my friend. It would work fine for heating it but no more.
2011 CATERPILLAR TH337AG TELESCOPIC LOADER (A64279)
2011 CATERPILLAR...
2020 FREIGHTLINER M2 106 4X2 S/A 26FT TARP SIDE BOX TRUCK (A59912)
2020 FREIGHTLINER...
2019 KENWORTH T880 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T880...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2018 Ford F-150 4x4 Pickup Truck (A61573)
2018 Ford F-150...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
