Need info about lathe bits
/ Need info about lathe bits #21
To answer the question at hand, I make my parting blades out of broken hacksaw blades. I grind the teeth off of the edge and then grind whatever shape I want on the cutting face, including tapering the sides if needed. I always have new stock when one breaks.
But, I have concerns over your plan to cut through 3/16" metal with one tooth. You'd be far better off using a rotary cutter. I know of an electronics shop that cuts all of their panels on an engraving table. Even with a carbide rotary engraving bit, it is pretty s-l-o-w because of the multiple passes (and they cut only plastic and aluminum panels).
I've found that a Sawzall is about the best you can get for a wide variety of cutting needs, so perhaps you can find a used one at the flea market.
Good luck!
- Just Gary
I was in Lowes today killing time
and I noticed they had mapp/oxy torches with disposable tanks for $50.
I think I'll get one of them. can also use propane.
No more stuff than I do it should work great.
But I'm gonna post a seperate question about it to get opinions.
Pooh Bear
/ Need info about lathe bits #23
Bear you're not going to cut steel with disposable bottled gas from Lowe's my friend. It would work fine for heating it but no more.
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2011 PETERBILT 367 (A65643)
2011 PETERBILT 367...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
John Deere 2840 Tractor (A64047)
John Deere 2840...
Behlen Grain Bin Aeration Fan (A65640)
Behlen Grain Bin...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
