Mowing Need help with water in gearbox.
   / Need help with water in gearbox. #1
csharpe5097
NY
Kubota L4240
I have a 10 year old JD brush hog and i changed the gear oil and the seal last year. I brush hogged an acre today and found that the gearbox already had water in it. What can i do to keep water out. Thanks for your help.
   / Need help with water in gearbox. #2
Is the gearbox breather not plugged with dirt?
   / Need help with water in gearbox. #3
If you store you cutter outside, suggest you put a cover over the gearbox.
Is that the bronze fitting on top. I will check it. Thanks
   / Need help with water in gearbox. #5
Pack gearbox with standard grease.
JPC
   / Need help with water in gearbox. #6
It will draw water in through the vent, or through the seals sometimes best is to cover it from the weather.:thumbsup:
Thanks all. I changed gear oil and replaced seal. I will cover it when stored.
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
2016 Lincoln MKC SUV (A55853)
2016 Lincoln MKC...
John Deere 1025R (A53317)
John Deere 1025R...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A55315)
Magnolia Trailer...
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
