Mowing Need help with water in gearbox.
   / Need help with water in gearbox. #1
csharpe5097
NY
Kubota L4240
I have a 10 year old JD brush hog and i changed the gear oil and the seal last year. I brush hogged an acre today and found that the gearbox already had water in it. What can i do to keep water out. Thanks for your help.
   / Need help with water in gearbox. #2
Is the gearbox breather not plugged with dirt?
   / Need help with water in gearbox. #3
If you store you cutter outside, suggest you put a cover over the gearbox.
Is that the bronze fitting on top. I will check it. Thanks
   / Need help with water in gearbox. #5
Pack gearbox with standard grease.
JPC
   / Need help with water in gearbox. #6
It will draw water in through the vent, or through the seals sometimes best is to cover it from the weather.:thumbsup:
Thanks all. I changed gear oil and replaced seal. I will cover it when stored.
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
3pt 2 Row Plow (A53317)
3pt 2 Row Plow...
