Mowing Need help with water in gearbox.
   / Need help with water in gearbox. #1
csharpe5097
NY
Kubota L4240
I have a 10 year old JD brush hog and i changed the gear oil and the seal last year. I brush hogged an acre today and found that the gearbox already had water in it. What can i do to keep water out. Thanks for your help.
   / Need help with water in gearbox. #2
Is the gearbox breather not plugged with dirt?
   / Need help with water in gearbox. #3
If you store you cutter outside, suggest you put a cover over the gearbox.
Is that the bronze fitting on top. I will check it. Thanks
   / Need help with water in gearbox. #5
Pack gearbox with standard grease.
JPC
   / Need help with water in gearbox. #6
It will draw water in through the vent, or through the seals sometimes best is to cover it from the weather.:thumbsup:
Thanks all. I changed gear oil and replaced seal. I will cover it when stored.
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2020 DRAGON ESP...
72in Forklift Basket Attachment (A56857)
72in Forklift...
