Mowing Need help with water in gearbox.
   / Need help with water in gearbox. #1
csharpe5097
NY
Kubota L4240
I have a 10 year old JD brush hog and i changed the gear oil and the seal last year. I brush hogged an acre today and found that the gearbox already had water in it. What can i do to keep water out. Thanks for your help.
   / Need help with water in gearbox. #2
Is the gearbox breather not plugged with dirt?
   / Need help with water in gearbox. #3
If you store you cutter outside, suggest you put a cover over the gearbox.
Is that the bronze fitting on top. I will check it. Thanks
   / Need help with water in gearbox. #5
Pack gearbox with standard grease.
JPC
   / Need help with water in gearbox. #6
It will draw water in through the vent, or through the seals sometimes best is to cover it from the weather.:thumbsup:
Thanks all. I changed gear oil and replaced seal. I will cover it when stored.
Kubota SVL97-2 (A50120)
Kubota SVL97-2...
Case 585E Forklift (NOT RUNNING) (A50774)
Case 585E Forklift...
JCB 507-42 7,000LB Telehandler (A50322)
JCB 507-42 7,000LB...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
