Need help with tire chains
   / Need help with tire chains #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I broke down and purchased 2sets of diamond pattern chains. I never have really messed much with chains so excuse my ignorance here. I got them on just fine, but when I connected the two top chains ( the ones holding the diamond pattern together) I noticed they had sent these odd d rings. The straight part of the d was a screw. I opened the screw put the chains together and wrenched them down. Well, long story short after thoroughly enjoying the new found traction on 45 degree slopes I returned to find a number of my d rings missing. Can you guys recommend something better?
   / Need help with tire chains #2
D-rings mean different things to different folks ...pic or diagram? pointer to your chains or seller?
   / Need help with tire chains #3
I think the D ring you are talking about has a threaded pin with an eye on top. I safety wire my D rings with the wire running through the eye.
   / Need help with tire chains #4
Are you talking about shackles? If so I slightly modify them. On the pin I put an o-ring and on the outside of the non threaded hole I countersink it just a little bit. When you tighten the pin the o-ring squish out. I found a good place to buy them is Lowes, they have stainless ones for pretty cheap.
   / Need help with tire chains #6
Well. I had them installed wrong to begin with. Ken Simolo provided me with pix that showed me what I was doing wrong. Yes... Clevis. I bought some replacements and re ran the chains. Found some chain tensioners and already broke one. Will run the safety wire.
Thanks for all the advice.
Carl
   / Need help with tire chains #8
Bungee cord tensioners work well & are about free. I run two on the inside (+) , & three on the outside. (*). They held up fine thru a naty winter here last year.
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
Set of Ag R4 Wheels and Tires (A53472)
Set of Ag R4...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
