Need help with MMM
/ Need help with MMM #1
wxboy
Western MA
JD 2305
I recently tried to get my 54" MMM back on my 2305 and I can't get it back on. I did this a few times last year but it's been just about a year so I don't know if I'm doing it wrong or if the collar on the drive shaft has a problem.
When you hook the drive shaft up to the pto are you supposed to pull the collar back then push it on or does it just push on and then the collar locks into place? From what I remember I was thinking that you pull the collar back and then push the shaft on but when I try to pull the collar back it only moves about 1/16" so I tried just pushing the shaft on and that didn't work. I put some WD40 on the collar just in case it needed some lubrication to allow it to be pulled back but that didn't change anything.
I'm sure I'm missing something simple here that I just need someone to point out to me and then I will feel stupid but as long as I get the mower back on I can accept feeling dumb.
To make matters worse when I tried to roll the MMM under the tractor there wasn't enough clearance to get the deck under the tractor. That baffled me for a while but I figured out it is a combination of factors. For one the air in the tires was on the low side(16.5 psi) and the ballast box and loader were on the tractor further adding to the compression of the tires. Just thought I would mention this in case anyone else ever has the same problem.
/ Need help with MMM #2
Hooking the PTO up is a pain. You need to pull the locking ring back & it should stay locked back. Once you push the drive shaft onto the PTO the ring will snap into place.
/ Need help with MMM #3
The biggest thing that trips me up is remembering to put the applicable PTO into neutral (for example, selecting the rear PTO when hooking up the mower) so I can rotate the shaft and align the splines.
jdbower your tip worked. I had tried to spin the pto shaft before but I had the pto control lever on the mid pto so it didn't spin. Today I set the control lever on the rear pto spun the mid pto shaft by hand a little bit and the mower drive shaft collar slid right on.
Thank you, thank you!
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
2020 Ford Fusion Hybrid Passenger Car, VIN # 3FA6P0WU9LR128618 (A64557)
2020 Ford Fusion...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
213137 (A64276)
213137 (A64276)
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
