Need help with metal lathe!
   / Need help with metal lathe! #1
dliston
McHenry, Illinois - Right up near Wisconsin
New Holland TC40DA
Having a problem with my metal lathe. I can turn aluminum all day - no problems. Nice smooth finish - hardly needs filing to look great.
But I start turning steel and the tool chatters - really ends up giving me a bad finish - looks like I beat it with a punch. Do I have the tool set up wrong? Wrong speed? HELP!
/forums/images/graemlins/confused.gif
It's been too many years since metal shop in the eighth grade /forums/images/graemlins/mad.gif
Thanks,
Doug
   / Need help with metal lathe! #2
Kindof hard to tell what we're dealin with without a pic or description of your setup ... is your tool bit point set just above the center of the piece you're turning? Is the tool bit pointed at an angle to your piece rather than at 90° (angled toward the headstock). What kind of steel are you turning ... "free machining" (leadloy) will look close to an aluminum type finish but anything else may not.
   / Need help with metal lathe! #3
Try asking your questions in either or both of these forums. There are many home and professional machinists that can help. You will need to supply a little more info on the bit you are using and the machine setup.
Home Shop Machinists Forum
The Practical Machinist Forum
   / Need help with metal lathe! #4
I would say you have a bad tool, speed incorrect or feed incorrect. If these are wrong you could be surface hardening the metal.
   / Need help with metal lathe! #5
If it's an old lathe, it may have play in the spindle and/or chuck. You may also have the bit fastened too far from the cutting point, letting it vibrate up and down. Or your tool holder may be loose, causing vibration. Aluminum will cut a lot easier than steel, so you may not notice the problem while cutting aluminum. There are many reasons this may occur, but it's hard to diagnose from a distance.
Good Luck /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Need help with metal lathe! #6
Do you have the correct relief ground?
   / Need help with metal lathe! #7
Chatter is caused by a lack of rigidity. A basic rule of thumb is to keep your length/overhang ratio at 4:1 meaning a 1" diameter bar can hang out of the chuck 4".
Your tool needs to be fairly sharp. Slowing RPM can help.
Or you turning or Boring the inside of a bore?
   / Need help with metal lathe! #9
Great point! If over the 4:1 ratio, center drilling and using a live-center in the tailstock should help.
Cheers!
Magnum 125 Generator (A53421)
Magnum 125...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
