need help with loader control
/ need help with loader control #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Well, I finally have to come begging to TBN for some help! I got my trusty Kubota B8200 out last night after the plumber and his backhoe left, having done a septic line tie in and leaving a jumble of soil to be smoothed out, only to discover the loader was boogered! I don't think the hydraulics per se are the problem, since the power steering and the three point hitch work normally, but the loader (a Bush Hog QT840) goes up fine, curls one way fine, but doesn't want to down or curl the other way. When you put the control in float, the bucket goes up! Which makes me think the control valve is acting up. Now what? Can I take it apart and look things over, or is it something that needs professional experts? (I "rebuilt" a VW's fuel injection distributor some 30 years ago, and it almost ran after the third time- to be fair, my shop guys told me it couldn't be done, and the o rings weren't available anywhere). Thanks to those who have tread the path before me. Varmint
/ need help with loader control #2
Check the joystick linkage. I'll bet you have some crap in there that is screwing up the linkage where it attaches to the spools.
/ need help with loader control #3
What Mad said plus check your connections. Have you had the loader off recently? Make sure each connection is the right pair and that they're fully seated. Hope you get'er straightened out /forums/images/graemlins/smile.gif
I haven't touched the connections or anything else concerned with loader for quite a while- and everything worked just fine about a week ago. I suspect the control valve since it works fine in about half the modes. Nothing obvious is wrong. I'll get back when I have time to check better. thanks.
/ need help with loader control #5
The symptoms you describe would not be related to a spool internal malfunction unless the end cap or handle cap has come loose and the spool rod itself is no longer properly seated. This should be easy to see without much, if any, disassembly.
I will still place my money on a linkage problem, either loose or impeded by some form of trash.
/ need help with loader control #6
I had a problem similar to this on my 7800 and I had left the 3pt hitch lever up (pumping) and the loader would raisee and curl up but would not go back down or curl down. My 7800 has the 1/4 inching valve instead of position control (not sure if that makes a difference or not). Just thought I would throw that out there.
Good luck
So far, I did check the connections and joystick linkage, all of which were fine and normal. I called Bush Hog, and they think it may be a valve issue... I will check out the 3-point issue, since I had just removed the rear blade and installed the auger, and moved up and down a bit in the process, but I have a position control, and I don't think it would create such a problem.
/ need help with loader control #9
It sounds to me that you have a back pressure problem. If you lower your three point the loader should work fine. To make it work right all the time you would need a valve that offeres power beyond. You may want to contact the loader MFG and ask if they offer a Power beyond setup for the valve you have. We have seen this problem before and it's usually because the loader valve is hooked up infront of the three point. If you don't raise your three point all the way (keeping the 3 pt valve open), your loader should work fine. Let us know if this info helps. Thanks
Thanks for the ideas: and keep in mind that the present set up has worked just fine for years. After talking to the Bush Hog tech guys (who were really helpful and easy to deal with, to their credit) it is determined that the seals in the valve are shot, so I have a rebuild kit on order. I will let everyone know how this evolves.
/ need help with loader control #11
I would still lower the 3-pt, then try the loader valve. If it was a seal in the valve, I find it hard to believe that both spools could go at the same time. Please try lowering the three point. Thanks
Hey, Koykermfg and all the others who offered advice: I got an expensive oring kit for the loader control, but I haven't had the time to install it. Today, I decided to drill some post holes that I needed, and then to take the tractor to the shop to tackle the valve. It still didn't work (the loader, that is) BUT after many up and downs with 3 point hitch working the auger, the loader once again worked fine. So- you guys were correct, and I didn't work the 3 point enough to unload the hydraulics. Next time, I will follow smarter people's advice from the get go, before I waste money! Thanks again.
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
Root Rake Loader Attachment (A61567)
Root Rake Loader...
KUBOTA MX5800 TRACTOR (A62130)
KUBOTA MX5800...
2013 Komatsu PC210 Excavator (A60352)
2013 Komatsu PC210...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61307)
Midwestern...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
