Need help with JD Autotrac
   / Need help with JD Autotrac #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
JD 6R 145. I successfully set up a random curve along the edge of a field and it will steer itself along that path. But when I move over to make another pass, I get the message that autotrac has disengage due to being too far off track. I can run straight lines with no problem. What's different about trying to follow a random curve?
   / Need help with JD Autotrac #2
I know nothing about the software but thinking of the problem mathematically I wonder if it has something to do with it being a smaller radius?
Well I finally found some info online and I think I have it figured out, but I'll have to try. Looks like I should be using A-B Curve instead of Adaptive Curve
   / Need help with JD Autotrac #4
I believe you are correct on the A-B curve since that should follow the path you created. Have only used that function once though so memory could be wrong once again.
   / Need help with JD Autotrac #5
I know this is old, but in case it helps someone else.
You need to set up the guidance so that it records a line every pass when you lower the implement. You have to record a new line as you are following the previous line while in Adaptive Curve.
If you only want to record the line once and follow that same original line, just copied in either direction offset by your track spacing, then use AB Curve.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Portable Restroom (A54865)
Portable Restroom...
2016 Peterbilt 337 Corrosive Flammable Liquid Transport Truck (A55973)
2016 Peterbilt 337...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
