Need help with JD Autotrac
   / Need help with JD Autotrac #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
JD 6R 145. I successfully set up a random curve along the edge of a field and it will steer itself along that path. But when I move over to make another pass, I get the message that autotrac has disengage due to being too far off track. I can run straight lines with no problem. What's different about trying to follow a random curve?
   / Need help with JD Autotrac #2
I know nothing about the software but thinking of the problem mathematically I wonder if it has something to do with it being a smaller radius?
Well I finally found some info online and I think I have it figured out, but I'll have to try. Looks like I should be using A-B Curve instead of Adaptive Curve
   / Need help with JD Autotrac #4
I believe you are correct on the A-B curve since that should follow the path you created. Have only used that function once though so memory could be wrong once again.
   / Need help with JD Autotrac #5
I know this is old, but in case it helps someone else.
You need to set up the guidance so that it records a line every pass when you lower the implement. You have to record a new line as you are following the previous line while in Adaptive Curve.
If you only want to record the line once and follow that same original line, just copied in either direction offset by your track spacing, then use AB Curve.
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 Dodge Ram 3500 (A57148)
2018 Dodge Ram...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
