Need help with injector pump timing question.
/ Need help with injector pump timing question. #1
thetester
Benton MS
3414 IH
Hey guys I know most of you will grumble about chiniesium tractors but that's what I got.
I just purchased a little farm pro 2420. It had a knock in the rear cylinder. There was some white smoke and more if I throttle up. sooo off to the races to figure it out. I noticed that one of the studs holding the injector in was missing. This told me someone suspected issues back there before.
I knew it could be a leaking injector causing fuel knock. So maybe not a rod or at least I hope not. So I took the injector out, took it apart and cleaned it. I reinstalled with a new stud that was missing. Immediately it fixed 80% of the knock. I can still hear a faint resemblance of a knock but I really REALLY have to try hard to find it.
There is still a slight amount of white smoke and if I ramp the throttle a bit more. I believe it's unburnt fuel.
The guy I bought it from said the injector was replace recently so I figured I have some timing issues. This would explain the smoke and likely the detection of a faint knock.
The problem is I'm not so sure how to go about fine tuning this pump?? I see what appears to be two bolts. One on top and the other on the bottom. One on top is a pivot and the one on bottom is packed for lateral adjustment. There are no manuals and little usable info out there on these tractors. Without years of aquired knowledge on diesel mechanics, it leaves me holding my hat.
What's the best approach to attempting to fine tune the pump? How would you guys go about it??
Interesting they are selling these! They are free and freely shared! Those are parts diagrams and lists. Operators manual is also free and have those.
There are no maintenance manuals. What info I could find does not go into detail on tuning the pump.
I can find a general description on replacin in punp in general but it doesn't explain how to fine tune the time how or why???
THEY all say you may have to fine tune your timing?
/ Need help with injector pump timing question. #4
Not sure where you are in the process on fixing your tractor, but if I had a situation where cleaning 1 injector eliminated 80% of the knock I was hearing, I would clean the other injectors prior to adjusting timing.
My thoughts are if one injector was dirty, why would the others not be.
That is not saying that a typing adjustment might not be needed.
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
John Deere 2155 (A62177)
John Deere 2155...
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
213135 (A64276)
213135 (A64276)
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
