Need help with Grapple 101...
/ Need help with Grapple 101... #61
I just bought the same GL5740 rops w/ r4's with a horst welding 72" Scrap Grapple bucket Ive had some trouble with the breakout force of the loader frame even with the reg material bucket had reliefs adjusted once and frankly id like a little more. My grapple weighs 850 empty. As some have said it sounds heavy but the machine specs show it should handle it. I operate with loaded rear tires and a timber winch my main job with this is firewood
/ Need help with Grapple 101... #62
Your tractor will absolutely "handle" the weight of the grapple, just not a whole lot more. If your only picking up brush it should be fine, but a 72" 850lb grapple, is too much for a tractor our size. You may take a hit, but I'd suggest selling that grapple and buying a lighter duty one if your doing much more than lifting lightweight/bulky objects. Either that, or it's a good excuse for a larger tractor :D
/ Need help with Grapple 101... #63
Exactly. A 850 lbs bucket is for heavy duty construction machines like 12,000 lbs Bob Cat skid steers The tractors are just not set-up for heavy buckets like these. All your lift force is going towards moving the bucket.
850 lbs is ALOT of weight for a tractor that weighs around 6,000 lbs. Sell the grapple and buy one that's more in scale with the tractor. You will be happy that you did.
/ Need help with Grapple 101... #64
Completely agree. To pick up firewood, a light duty 48 or 60 inch grapple is probably your best bet. Or, as firewood in 18" lengths can be tricky for any grapple, consider adding a wide grapple top arm to your standard bucket and just use that. A standard bucket is almost as efficient as a grapple with small items like cut firewood. If you are talking 4-8ft lengths then a 48" grapple will leave you with the greatest net lift power and will be more than adequate to hold a load stable while traveling.
We went with a 48" wr long I believe is the manufacturer. We have only had it a couple of weeks but love it so far. Haven't moved any heavy trees rye, just used it to organize some burn piles. It is about 350 lbs which leaves some weight room for lifting bigger stuff than we have so far.
/ Need help with Grapple 101... #68
/ Need help with Grapple 101... #69
Hey Island, Finally bought my 60" grapple from MIE and hose kit. Going to be a fun summer I hope.
Grappling stuff that would be a major pain to move otherwise is one of the very best applications for a CUT. I'd rank the grapple right after the mower on a list of best bang for the buck implements.
/ Need help with Grapple 101... #72
Island, what I meant was that I spent a lot less for my new grapple than I did for my used Bush Hog and use the former much more than the latter, hence the I get more "bang for the buck" from my grapple.
/ Need help with Grapple 101... #73
Yep. I got my 48" Millonzi via an eBay auction I won for $500. I think I paid another 100 for shipping. Probably half of my tractor hours have been using that grapple so by those standards it is the best bang.
Hays LT1 Tender (A61307)
Hays LT1 Tender...
(APPROX. 13) CASE INTERNATIONAL WEIGHTS (A63290)
(APPROX. 13) CASE...
CASE IH TURBO 330 - 34' TURBO TILL (A63290)
CASE IH TURBO 330...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
2000 CHEVROLET 3500 SERVICE TRUCK (A63290)
2000 CHEVROLET...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
