Need Help with Error Message on a 4320
/ Need Help with Error Message on a 4320 #1
m_magpies
Oklahoma
John Deere 4320 2006
I have a JD 4320. After bush hogging for about three hours the malfunction light started to blink. On the display it had an error code of either "cenph1" or "eenph1." I could not find this message/code any where in the owner's manual. Anyone know what this means? After I started the tractor back up the message went away. An hour or so later it came back on again.
/ Need Help with Error Message on a 4320 #2
Highest likley cause is a loose wiring connection. Something snagged a wire connector under the tractor and it is loose. I had this a couple of times on the 4wd engaged sensor.
/ Need Help with Error Message on a 4320 #3
I'm not sure--but don't most (maybe all) of the error codes start err__? Any chance it was sending eeprom messages--only thing I could think of that was close.
2012 Ford F-250 6.7L Diesel, 4WD (A62679)
2012 Ford F-250...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
Quick Attach Backing Plate (A65579)
Quick Attach...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
JOHN DEERE 544J...
