need help with compact tractor purchase
/ need help with compact tractor purchase #1
iva
I am looking for a compact tractor capable of pulling a disk, loading, planting, auger attachment, and rough cut mowing. However, I am unsure what model or horsepower to purchase. Please help
/ need help with compact tractor purchase #2
</font><font color="blue" class="small">( I am looking for a compact tractor capable of pulling a disk, loading, planting, auger attachment, and rough cut mowing. However, I am unsure what model or horsepower to purchase. Please help )</font>
How much acreage ?
How big of discs ?
How big of mower do you want to run ?
We need more information to answer you question.
/ need help with compact tractor purchase #3
I would start with at least 30 HP diesel maybe more depending on how much acreage. Also, get the 4WD also known as MFWD on a compact. This will help pull about a 6 ft wide disc.
Look at the 790 and 4310 models or bigger depending on your budget versus your spare time.
/ need help with compact tractor purchase #4
iva,
With the work your talking about your not going to want an HST
Look at a 12x12 PowerReverser and also 4WD /forums/images/graemlins/grin.gif(4510)
I have 15 acres and will be doing some of the things you have talked about, but it will depend as previously stated it depends on how many acres you plan to do this work on.
Good luck and keep us posted /forums/images/graemlins/grin.gif
/ need help with compact tractor purchase #5
You state no HST?
WHY, does it make you feel good to shift?
If you get a CUT that has the HP for what you are doing
It will make no difference.
DPR
/ need help with compact tractor purchase #6
If the HST tractor has cruise control I guess it would be OK, but I would hate to pull a disc over a plowed field and try to hold a HST pedal steady. I plowed and disc about 6 acres over the weekend and was glad I could put my 4310 with shuttle shift in gear and forget it.
/ need help with compact tractor purchase #7
Oh no. Not another hydro vs. gear debate.... /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
/ need help with compact tractor purchase #8
I am NORMALLY a strong advocate of HYDRO but in this case we have someone who is looking for a recommendation on a tractor that will be planting, disking, etc. Those tasks are generally considered to be gear tractor tasks because they are agricultural tasks, not small estate/yard maintenance tasks.
We really don't have enough information about land size so tractor HP is pretty tough to recommend, I think if we had more information we could make an informed choice. Even the choice of Hydro vs Gears is tough in this case because of the lack of information. If we knew that it was 1/2 an acres that was going to be farmed versus 5 or 10 or more acres we could begin to think about HP and gears.
2021 KUBOTA SVL97-2 SKID STEER (A64279)
2021 KUBOTA...
213096 (A64276)
213096 (A64276)
2017 Chevrolet Cruze Sedan (A61574)
2017 Chevrolet...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2002 48ft. 38 Ton T/A Flatbed Trailer (A61573)
2002 48ft. 38 Ton...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
