Need help with a ford 3000 select o speed.
   / Need help with a ford 3000 select o speed. #1
Aarons3000
Danville Missouri
Ford 3000 sos
My tractor wants to pull foward when inching pedal is pushed in even in reverse gears. Some one told me that the valve body was bad. Put a different one on and still no change. I have adjusted the bands to spec. Its gettin where you really have push down on the brakes to hold it. Oh and it has a slight pull I neutral. I'm out of ideas here. And help is appreciated.
   / Need help with a ford 3000 select o speed. #2
My 3000 has done the same thing the entire time I've owned it, its more pronounced when cold. It was rebuilt by the New Holland dealer then used about 300 hours before I purchased it . Soundguy might be able to help? My understanding is this is fairly normal for the SOS machines although most posts say light brake pressure is normally all that's needed to keep it from moving, also I do think the (trick) is in the band adjustments- not the valve body, hopefully someone who has been able to fix this on their own machine will chime in...
I agree. Mine has always had a little bit of creep not an issue. But now it's bad. I wouldn't want anyone to drive it that isn't fimilar with it. Mabey I will triple check my bands. I've adjusted the all at operating temp.
I think I did forget to mention when I go through the gears and back to park it seems to bog the engine down like its got a load on it.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
