Need help with a ford 3000 select o speed.
   / Need help with a ford 3000 select o speed. #1
Aarons3000
Danville Missouri
Ford 3000 sos
My tractor wants to pull foward when inching pedal is pushed in even in reverse gears. Some one told me that the valve body was bad. Put a different one on and still no change. I have adjusted the bands to spec. Its gettin where you really have push down on the brakes to hold it. Oh and it has a slight pull I neutral. I'm out of ideas here. And help is appreciated.
   / Need help with a ford 3000 select o speed. #2
My 3000 has done the same thing the entire time I've owned it, its more pronounced when cold. It was rebuilt by the New Holland dealer then used about 300 hours before I purchased it . Soundguy might be able to help? My understanding is this is fairly normal for the SOS machines although most posts say light brake pressure is normally all that's needed to keep it from moving, also I do think the (trick) is in the band adjustments- not the valve body, hopefully someone who has been able to fix this on their own machine will chime in...
I agree. Mine has always had a little bit of creep not an issue. But now it's bad. I wouldn't want anyone to drive it that isn't fimilar with it. Mabey I will triple check my bands. I've adjusted the all at operating temp.
I think I did forget to mention when I go through the gears and back to park it seems to bog the engine down like its got a load on it.
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
