Need help with 1967 Ford 3000
   / Need help with 1967 Ford 3000 #1
big george
Fulton md
Ford 1967 3000
How do you replace the filter in the power steering pump? There is a spring inside that is making it difficult to reattach.
   / Need help with 1967 Ford 3000 #2
I remember it being a little tricky to replace the reservoir cover as well due to the spring when I changed the filter and fluid on my 4100. If i recall it took me and another person, one to hold the reservoir cover and the other was applying pressure on the bolt and turning it simultaneously with a battery impact. Be careful that you don't strip the threads if you use a battery or pneumatic gun.
I don't have help and I do not have a battery impact just Old fashion wrenches .
   / Need help with 1967 Ford 3000 #4
It was impossible for me to get everything lined up, so I removed the power steering pump and reassembled it off of the tractor. Only two bolts hold the pump on from the front. Don't forget the pump to engine o-ring if you go this route. This is only for the pump with integral reservoir, which maybe didn't start until '68.
2019 Komatsu WA470-8 Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Diesel Engine, JRB (A59076)
2019 Komatsu...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
